Car wont make commanded Boost. I give up!!!!
Old Jun 23, 2015 | 07:01 AM
  #46
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Finally had a few minutes to work on the car last night. I had enough time to take the y-pipe off and confirm the TB plate was working like it should. It was working perfectly and opening 100%. So if it is the TB the computer is telling it to close for some reason but I don't think that it is.
Old Jun 23, 2015 | 11:09 AM
  #47
I sent him a recall file for Durametric it will log everything including the actual throttle position.
Old Jun 23, 2015 | 03:39 PM
  #48
BLKMGK's Avatar
Awesome, I hope,that the data Marski is after finds the problem. I'm dying to know what the issue is!
Old Jun 23, 2015 | 03:41 PM
  #49
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Have you checked the pop valves or penny valves in the turbo to make sure the seats arent cracked as they will never seal if they are.
Old Jun 24, 2015 | 03:55 PM
  #50
NTIMD8's Avatar
OK well here is the log file for a 3rd gear pull.
For some reason when you save it, it saves as a .php file so you will have to change it to .xls in order for it to go back to an excel file and you can open it..
Thanks!
File Type: xls
Old Jun 24, 2015 | 04:16 PM
  #51
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Throttle is staying open, so that's good. The only thing that looks off to me is your injection time. It's dropping off at high rpms when it should be increasing. I'm no expert, so maybe someone else can give some more input.
Old Jun 24, 2015 | 05:02 PM
  #52
Here is nothing wrong with the car. Your wgs are set to crack to low. Make sure they start at 15 psi and your issues will go away
Old Jun 24, 2015 | 05:10 PM
  #53
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
Just as a helpful hint. Markski is NOT saying fully open at 15psi. He is saying at 15 psi is when they barely should start moving.
Old Jun 24, 2015 | 05:28 PM
  #54
NTIMD8's Avatar
Markski, I will try it but like i mentioned before, the car wouldn't boost anymore even with the wastegates actuators bypassed and even wired shut so I'm not sure how adjusting the actuators will help.
Thanks so much for your help!!!
Old Jun 24, 2015 | 06:22 PM
  #55
I will suggest logging pulls with every change you make. You might notice something different and the extra data could be helpful.
Old Jun 24, 2015 | 06:43 PM
  #56
I understand but why don't you try what we know works and then do a log. I've never wires then shut thus can't tell you what it should be like. But I do know wgs are set to low the car will act like it should. I'm not sure why the wgs were at 11 or 12 psi to begin with. They should be at 15 psi. That's when u should see the arm to crack to move.
You will see that all this time, if every everuting else is ok like book leaks that you will solve your issue. I know logs and I know how to fix it. This is what I do
Old Jun 24, 2015 | 06:59 PM
  #57
NTIMD8's Avatar
Sound good. I will set them to crack at 15psi and report back. Thanks again!!!
Old Jun 29, 2015 | 06:27 PM
  #58
stilov's Avatar
Any update?
Old Jun 30, 2015 | 07:02 AM
  #59
NTIMD8's Avatar
Originally Posted by stilov
Any update?
Unfortunatly no. This weekend I had to throw the built LS6 back into the RX7 so I wasnt able to touch the Porsche. I will try to adjust the actuators sometime this week and report back.
Old Jun 30, 2015 | 08:56 AM
  #60
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
do you checked the check valve on top at the TB Intake Plenum?
