Car wont make commanded Boost. I give up!!!!
Old Jun 30, 2015 | 09:25 AM
  #61
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Originally Posted by winnigt2
do you checked the check valve on top at the TB Intake Plenum?
My understanding is if that check valve is bad it will show when doing the boost leak test by releasing the air into the drivers side turbo inlet. Or is that not the case or are you talking about a different check valve?
Old Jun 30, 2015 | 10:33 AM
  #62
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
correct
Old Jun 30, 2015 | 10:44 AM
  #63
NTIMD8's Avatar
correct
In that case, yup I checked it. lol
Old Jun 30, 2015 | 02:06 PM
  #64
32krazy!'s Avatar
put the ls6 into the porsche!
Old Jun 30, 2015 | 02:12 PM
  #65
The logs are fine the wgs are set too low. Crank them up to 15 psi to start to crack open instead of 11 psi like you have it and you run 1.3 bar.
Markski
Old Jun 30, 2015 | 02:22 PM
  #66
'02996ttx50's Avatar
you'll "hear" it if it's bad and as stated above its atop the tb/plenum ( #16 in the parts diagram if you have it? ) as all it can do is crack pls ( correct me if i'm wrong ) but its just a little piece of plastic. the other ( iirc ) is a venturi tube. it inhibits boost constantly if messed up. wg adjustment or not. i went thru all this.
edit> didn't see you'd already confirmed it's working pzzzzt. sorry.
Old Jul 1, 2015 | 12:31 PM
  #67
From my understanding he did extensive proper boost leak tests....I doubt its the n75 and or the lines to it... it would show...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 1, 2015 | 03:42 PM
  #68
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
haha and twin turbos!!
Old Jul 1, 2015 | 04:12 PM
  #69
NTIMD8's Avatar
Would you also know if the Venturi tube is messed up by doing a boost leak test?
Thanks!
Old Jul 1, 2015 | 04:14 PM
  #70
NTIMD8's Avatar
Markski
I really hope so. lol
Old Jul 1, 2015 | 04:15 PM
  #71
NTIMD8's Avatar
And put the Metzger in the RX7? Too much work because I already installed the nitrous in he RX7. lol
Old Jul 1, 2015 | 04:45 PM
  #72
Thanks!
Not that I'm aware of...but I have always mistakenly referred to these as both check valves while that isn't exactly so. The only one that I personally have ever found cracked was the check valve @top TB/plenum though I did also change the check valve, venturi tube, & n75 same time.
My bud told ne given they work in concert and are penny items just change em all
Old Jul 2, 2015 | 05:48 PM
  #73
NTIMD8's Avatar
I had some time to work on the car today. I removed the exhaust to physically check the wastegate flappers and they looked fine and sealed well. So I did as Markski said and set the actuators to crack at 15psi. Here is a log after doing so. I unfortunately still don't see 1.3bar on the gauge.
File Type: xls
Old Jul 2, 2015 | 05:58 PM
  #74
Ok
If you do the test let's say to 15 psi on the wgs , do they actually hold it or do they leak down ?
I would check that on each side and also turn then up to 17 psi just to see.
If that doesn't help, can you verify that at the lower boost hoses you did a pressure test to 20 psi and holds 20 seconds without dropping ?
Old Jul 2, 2015 | 06:07 PM
  #75
NTIMD8's Avatar
Ok
Hi Marksi,
I just did a comparison of the first log and now this log. It looks like it is holding more boost now at each respective RPM with the actuators set to crack at 15psi so at least we are heading in the right direction.
Yes when I used the mityvac to set the actuators they held at that pressure for at least the 5 seconds I held them there for. Should I see if they hold for longer? Im not sure how much tighter I can make the actuators. Im running out of thread on the rod. lol I will see if I can get them to 17psi.
And yes it held 20psi for a while when I did the boost leak test. Here is the video...
https://www.youtube.com/watch?v=QIzm...ature=youtu.be
