Rotor minimum thickness and pads...
Old Aug 18, 2015 | 04:48 AM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Hey guys I had service done on my car and was told the front brakes are at 15% and the rotors at minimum wear..
I don't track the car just blast it on the street here and there... Few questions:
1) what's minimum thickness for rotors?
2) if I'm at or close to it can I put pads only as long as it's not below?
Realize new rotors are the best but with a 1 and 4 year old and daycare right now, you know how it is . I'm fine to do rotors if needed but don't want to if I can get away with pads.
Thanks for any advice.
Old Aug 18, 2015 | 04:58 AM
'02996ttx50's Avatar
oem coated "ate" rotors are 75 bucks each at pelican. when in doubt. as long as they are not ridged at top of the rotor you still have enough tolerance for another set of pads. oem pads are also only 75 bucks. so if you can r&r yourself, these are very inexpensive maint items(s). just did mine frt/rear.
Old Aug 18, 2015 | 07:05 AM
jpflip's Avatar
Front disc: new 34mm (1.34") min. limit: 32.6mm (1.28")
rear disc: new 28mm (1.1") min.limit: 26.6mm (1.05")
Name:	Screen Shot 2015-08-18 at 08.56.06.jpeg
Old Aug 18, 2015 | 09:43 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
To be clear, the 32.6 is the minmum thickness after machining.
From wear, you can go down to 32mm
Old Aug 18, 2015 | 11:26 AM
rmc1148's Avatar
I honestly think you would be fine but I personally would change rotors/pads and skimp somewhere else like mods= safety first..
Old Aug 18, 2015 | 03:21 PM
agree. i mean its all four corners for 300 bucks! if you stay oem (?
) and it takes about an hour to change front AND rear pads AND rotors. nothin to it.
Old Aug 18, 2015 | 05:58 PM
King James's Avatar
$300? I priced rotors and pads at $800 cheapest locally. Guess I need to check pelican.
[edit]Dang that's cheap at pelican. The brand is ATE who they specify Iran OEM supplier to Porsche is that what you bought ?
Even with shipping to the great white north it's still cheaper
Old Aug 18, 2015 | 07:28 PM
yes, ate brand ( oem supplier ) at pelican for 78 a copy!. if you can see any diff? ( and yes, they're coated ) i'll ate a pelican
first time i changed em. theyre heavier than bricks!
Old Aug 20, 2015 | 03:16 PM
alwaysnboost's Avatar
alwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond reputealwaysnboost has a reputation beyond repute
Wondering if the Zimmerman's worth the extra money for the weight savings? Also, without deviating too far off topic has anyone here have any experience with Zimmerman or ATE rotors with Hawk HPS pads?
Old Aug 20, 2015 | 03:33 PM
rmc1148's Avatar
I have ran Zimmerman (use to be OEM I believe) many times in the past with good results, know nothing about ATE.
cayguy0521
Cayenne 958
Oct 8, 2015 12:37 PM
Goonie
Sep 12, 2015 02:10 AM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
