massive wheel hop
Old Sep 12, 2015 | 08:40 PM
168's Avatar
168
168 is infamous around these parts168 is infamous around these parts
massive wheel hop
Hey guys. Need some advice here. I've been getting wheel hop every time the car hits 1 bar and over on second and third gear. I've tried softening my kw v3's, and lowering tire pressure. I'm currently running on a set of brand new r888. Weather has been warm, so I wouldn't think road conditions play a part.
My car is converted to rwd with EVOMS GT775 kit. This just started becoming an issue recently.
Any thoughts or guys that have come across this problem?
Cheers
Old Sep 12, 2015 | 11:30 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
check engine and trans mounts, also check suspension bushings
Old Sep 13, 2015 | 01:46 PM
168's Avatar
168
Thanks Rob. Hopefully it's one of those things. Can't even go WOT now.
Old Sep 14, 2015 | 02:21 PM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
I'd second those suggestions. If you find issues, we recommend a new OEM updated transmission mount, and RSS engine mounts. They'll lock things down nicely without causing any excessive vibration or noise.
Can you tell if it's coming from one side of the car or another? I would inspect your shocks to make sure you don't have one going bad as well. Usually this can be felt in other situations than straightline acceleration, but when I was in MN we'd see this if cars ever saw cold weather or winter driving (even if it was usage in wet/snow melty Springtime).
Sam
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Sep 17, 2015 | 11:49 AM
168's Avatar
168
Sam
Thanks Sam. Not noticing it from a particular side, but will pay more attention now that you mentioned. Suspension has he ended checked and appears to be fine.
Old Sep 17, 2015 | 11:54 AM
Bader996's Avatar
Bader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud ofBader996 has much to be proud of
I had the same issue , it was from the rear passengers side shock . Changed both and it's been fine since
Old Sep 19, 2015 | 04:38 PM
168's Avatar
168
How did you determine it was from the shock? Mine look fine and everything below looks tight.
Just changed out the motor mounts to solid ones, and car is still the same.
Any other suggestions?? Transmission mount going on next.
Old Sep 19, 2015 | 05:03 PM
32krazy!'s Avatar
i don't know that solid mounts would be the route to go for me semi solids are my choice. my shocks were shot when i got the car but didn't know it as i never owned a pcar before. after some research and talking to olsen motorsports it was clear that after 7 yrs i need full rebuilds. the pics they sent me showed all the nitrogen had contaminated the fluid and it looks like fish eggs filled my shocks. after rebuilding it was like a different car
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
