Am I an idiot?
Old Sep 27, 2015 | 09:09 AM
  #31
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Originally Posted by rangerdick
So, here's the finished job. 42+- yards of concrete, a couple thousand pounds of rebar. A level garage and nearly level pad. Wait until 10/11 or so and epoxy floor covering, then drill and install floor anchors. I've got a list of about 5 lifts so far to do.
looks great man, that driveway looks steep though!
Old Nov 5, 2015 | 07:28 PM
  #32
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Thank you all for the great tips on the install. Did my first lift today. Changed the tranny and front differential oil. Man, what a time saver over a jack and stands. Plus so much more room. Ended up spacing the plates 127 inches apart. Was a bit nervous going under it at first. So I waited about 20 mins with the car in the air as I prepped other things. Went super smooth. As others have said, I think this will be one of the best purchases I ever made. Besides the TT
Old Nov 5, 2015 | 11:11 PM
  #33
BLKMGK's Avatar
If it makes you real nervous get a pole jack - Amazon has some - and set it up under the end of the car you're working on. If the car tries to drop on you the jack may be enough to keep it off of you.
Old phart
Sep 24, 2018 07:07 PM
Motams
Sep 28, 2015 07:41 AM
Casino_Royale
Sep 2, 2015 12:24 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
ZHZLS3
New Member Introductions
Aug 19, 2015 07:06 PM
