Failed CA Smog Test
Old Oct 16, 2015 | 09:12 AM
  #61
88mmm's Avatar
88mmm is infamous around these parts88mmm is infamous around these parts
Yup- We have the same inspection in NY and I had the same exact problem. I also have the V3 with the HJS Cats. After my tune was re-calibrated by EPL my monitors are now all set. Glad to see you got it sorted out without to much trouble.
Old Oct 16, 2015 | 11:30 AM
  #62
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Tony @ EPL was pro-active and contacted me a few days ago.
I am waiting to see what happens at the smog check station tomorrow. Else, the tune needs to be re-calibrated as stated above.
Old Oct 16, 2015 | 01:00 PM
  #63
88mmm's Avatar
Good he's a decent guy and he'll try to make it right for you. If you want to check before hand you can go to auto zone or the like and borrow their hand held scanner for free. This way you can check if the monitors are ready before you head to the smog station.
Old Oct 18, 2015 | 09:39 AM
  #64
996TWINS's Avatar
Still did not pass smog after driving 500+ miles.
PM'd Tony for his help.
Old Oct 18, 2015 | 10:47 AM
  #65
GT3 Chuck's Avatar
Administrator
I had my flash taken off and drove more than 500 miles and still did not have readiness...you need a very knowledgeable Porsche tech to use a PIWIS tool to obtain readiness or to determine if your flash is the problem otherwise you can be chasing your tail....considering the number of flashes out there I'm sure most California dealers have encountered this issue by now
Old Oct 18, 2015 | 06:40 PM
  #66
996TWINS's Avatar
Thank you Chuck, I will talk to my shop tomorrow.
Tony @ EPL has resolved this issue with a customer in another state in post here or in other forum.
I am wondering that this issue will be popping up with non-stock maps with other tuners when it comes time for the smog.
Old Oct 20, 2015 | 11:25 AM
  #67
996TWINS's Avatar
Contacted Tony and he is working on a solution.
Old Oct 20, 2015 | 12:51 PM
  #68
996TWINS's Avatar
^^^Thank you Tony for working on this.
My indy has been sending 4 to 5 cars a month to the smog referee station. He has been seeing 996 and early 997 models come up with issues even on non-tuned cars.
Old Oct 20, 2015 | 01:46 PM
  #69
'02996ttx50's Avatar
Originally Posted by Tony@epl
Im convinced that in 10 years... your not going to be able to own a car thats more then a few years old in CA.
man, ain't THAT the truth. at least tuned not "tuned" ones with "workaround solutions" anyway...sheesh.
"progressives", again. unfreakinbelievable
Old Oct 20, 2015 | 03:40 PM
  #70
996TWINS's Avatar
alifornia !!!
Old Oct 20, 2015 | 04:15 PM
  #71
32krazy!'s Avatar
On the stock cars run lower grade fuel and run the cars hard prior to trying to set readiness. Im convinced that in 10 years... your not going to be able to own a car thats more then a few years old in CA.
thats ok they will all die of thirst way before that
Old Oct 20, 2015 | 04:48 PM
  #72
996TWINS's Avatar
I drink beer anyway.
Old Oct 28, 2015 | 11:04 PM
  #73
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Flashed with Cobb OTS stage 1 map couple weeks ago. Finally got enough time to put some mileage on it and.... all monitors ready! Woohoo.
The tune drives smoother and is more tractable at low rpm to boot. I'm going to enjoy this tuning path going forward.
Old Oct 29, 2015 | 10:41 AM
  #74
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
The Latest Victim of the California Drought Is Beer
Old Nov 21, 2015 | 04:14 PM
  #75
San Diego 996tt's Avatar
San Diego 996tt is infamous around these parts
I just did my CA Smog check, and passed. This is with a GIAC tune, and quite a few non-obvious mods to the engine, but quite a few obvious mods to the rest of the car! I put a stock exhaust on it, cleared the ECU (shouldn't have done this), and went for a check. The tech said that he couldn't do the smog check because the computer was recently reset.
I drove it a few times, used my Innova 3100 OBD scanner to see that it had a green light for smog, and went back and passed. I did not go through the exact drive cycle that has been described. I think that those categories must include cumulative times rather than a specific sequence.
I had put the stock intake back on last year so that I wouldn't have to worry about visual inspections. I have to admit that i am really liking the quiet stock exhaust, too! Makes listening to the radio out on the highway much nicer. I'll have to see whether I stick the other one back on or not - probably just save it for when/if I turn it into a track car. The car makes a crazy amount of power even with the stock exhaust, and is so quiet!
Guess I'm showing my age, but it sure is nice to cruise down the highway listening to tunes!
Justin
