DV's replacing
Old Nov 23, 2003 | 06:22 PM
  #31
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Replacing the DVs is not meant to increase performance but rather reduce the possibility of them failing and thus reducing performance by leaking turbo boost...
You're preaching to the choir. Replacing good OEM valves with Baileys won't increase performance above stock.
But look at what you said; that failing valves reduce performance by leaking turbo boost. If there is "reduced performance" with bad valves, then replacing the bad valves with Baileys would "increase performance" back to the normal level.
My DVs were bad...they "honked". If they decreased my cars performance on anything but paper you could have fooled me, because I noticed no "increase or difference in performance" (i.e. back up to stock) with the Baileys installed. I'm talking seat of the pants difference.
I didn't have the Baileys installed as a "mod" to increase performance above stock, I replaced the valves because they were making noise, and I didn't want any degradation from stock performance. It turned out there wasn't any degradation in SOTP performance with the OEM "honking" valves.
Old Dec 20, 2003 | 05:10 PM
  #32
Cingulum's Avatar
Cingulum is infamous around these parts
What kind of BS is this?
The 996 TT OFFICIALLY produces a maximum boost of 0.8 Bar
Old Dec 20, 2003 | 05:28 PM
  #33
Joe West's Avatar
Joe West is infamous around these parts
Re: NEW DV INSTALLED
<gasp>!
Look how DIRTY that engine compartment is. Go clean it right now!
<grin>
Joe West
Originally posted by MJC123
OK, just got the car back with the new DV's replaced by Porsche under warranty...they are black so it is difficult to tell APPEAR to be metal as opposed to plastic....see the pic.
Prior to replacement, I could hit 1.0 bar (only mods are upsolute chip and a little tinkering with the stock exhaust), but it was a stretch and it would only hold for a second, and on the way home from the dealer tonight I hit 1.1 bar in 3rd gear and held it easily. Couldn't repeat due to traffic.
Old Dec 20, 2003 | 07:55 PM
  #34
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
He has a modified ECU. Thus more boost.
Old Dec 20, 2003 | 11:17 PM
  #35
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
Re: Re: NEW DV INSTALLED
Originally posted by Joe West
<gasp>!
<grin>
Joe West
Ya...oops....kinda embarrassing...anything I should beware of when cleaning the engine compartment, or can I just spray it down?
Old Dec 20, 2003 | 11:19 PM
  #36
MJC123's Avatar
Senior Member
Prior to my Upsolute chip .7 was my max (possibly due to faulty DV's?), but now will sustain 1.2.
Old Dec 21, 2003 | 12:57 PM
  #37
I thought that .7bar was max on the 6spds
I can reach .8 bar in my '02 six speed (stock except for Bailey's) if I go WOT in 3rd gear going up a hill, starting at ~2500 RPM.
Old Dec 21, 2003 | 01:09 PM
  #38
Of course, with this cooler weather, I am typically only seeing .6bar as I am sure that the ECU is adjusting to the higher O2 count in the cold(er) air.
The boost is "above atmosphere" (up the limits of the turbo's ability at high altitudes) , so the colder weather just means a more dense charge before boost.
Jun 10, 2017 07:45 PM
henryr
Sep 24, 2015 08:22 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
Jeff1smith
Aug 19, 2015 09:41 PM
