COBB owners with MAF-less tunes. Who did your tune?
contact sam at by design. he works closely with cobb and will likely have the answers you seek
Hi guys. I have done several with flawless execution. Sometimes because of the intake set up and sometimes because airflow meters can just be a PITA. Better throttle response as well. Cobb uses load calculating speed density and it runs great. It's an easy thing to just try. We can do the adjustment then you unplug your MAF. Easy to switch back before you commit. Hope that helps
Hi guys. I have done several with flawless execution. Sometimes because of the intake set up and sometimes because airflow meters can just be a PITA. Better throttle response as well. Cobb uses load calculating speed density and it runs great. It's an easy thing to just try. We can do the adjustment then you unplug your heater. Easy to switch back before you commit. Hope that helps
Thanks for the fast response. When is a good time to call you to get all the info to make the swap?
Thanks,
Rich
No problem. Next week will be a little funky with SEMA but I will have all my stuff with me. Send me an email with your ROM ID and current file that you are using. Data log if you have so I can take a look for you.
Nice!! Good luck with the Cobb mafless Tune! I'm sure it will run great! Have you decided if you are going to run fender intakes or just off the turbos? I'm thinking of getting some shorter filters and just running them off the turbos myself so I can put the upper intercooler ducting back on. Currently I'm running 3" fender intakes. Just food for thought.
