Tire slippage on rims on track, and wheel treatment
Old Jan 10, 2016 | 10:32 PM
BLKMGK's Avatar
Old Jan 10, 2016 | 10:38 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
yup, the key is improving friction/stiction, or going 10/10ths with a positive lock like knurling....also note the Z/28 is running Pirelli's as well, never seen a tire rotate so much, I'm getting really tired of it...going back to Falken's
Old Jan 11, 2016 | 01:23 AM
rmc1148's Avatar
On my old drag cars I would use screws, not done much today lol.
Old Jan 11, 2016 | 09:36 AM
pwdrhound's Avatar
Originally Posted by Macster
Whatever the Porsche techs use it works for my cars. Granted I don't track my cars and they are stock. But the Boxster can generate some serious g's on a hard/panic stop and the Turbo likewise and on the other gas hard throws some serious torque through the rear tires and I have never had a tire spin on the wheel.
It has been some time since I have watched a tech change a Porsche tire but doesn't the tire mounting machine run a bead roller along the wheel bead to separate and lift the tire bead away from the rim? If so my concern would be this would over time dull the knurling and make it less effective.
I'd also be concerned about the tire leaking.
Thus I'm leery of any wheel bead modification.
My preference would be to effect a suitable tire seal and tire to wheel bonding to prevent the tire from spinning on the wheel by some means that did not require modification to the wheel.
These are issues generally seen during track use with sticky tires, not street grocery getters. As such the generic maintenance manual stuff does not apply. Bead knurling does not cause leaks if done correctly. I've been using knurled wheels for several years without any issues. OEM manufacturers are now starting to use this technology on factory wheels. Nissan uses knurled bead wheels on the OEM Nissan GTR wheels for example.
Old Jan 11, 2016 | 12:52 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
Excellent thread..........had no idea many others shared the same issue.
Pwdrhound is correct, this is a track issue....sticky tires / heat / horsepower.
I run NT01s but prior to that also had the issue w/SportCups. We have taken steps to 'rough-up' the contact area and then thoroughly clean and dry mount new rubber.......helps some but not solve. With valve stem position marked on the side-wall, I would always see movement by mid-way through the 1st day of an event. By end of the 2nd or 3rd it's nuts.
I welcome the new ideas.....for the 2016 season. Thanks !
Old Jan 11, 2016 | 02:04 PM
pwdrhound's Avatar
Assuming you are using a non directional tire like an NT01 or a slick, you can flip the wheels side to side on the car every 3 or 4 sessions and that will tend to rotate the tire back into position. That's what I do to even out tire wear but it helps if you have an issue with tire slipage.
Old Jan 11, 2016 | 02:50 PM
Deuuuce's Avatar
Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !Deuuuce Is a GOD !
Originally Posted by OS Inspector
on our sand drag tires, we use bead sealant its pretty inexpensive. its a nasty black goo but it does hold air on tires with 3psi in them with 1000+hp shock loads of alcohol drag bikes/quads/rails
Corrected, 1000hp, correct?
I was going to ask the same - what about the drag racers??
Originally Posted by BLKMGK
This isn't something a street car is ever likely to see, track is far far more abuse, not even comparable.
Chevy had this issue with one of their Camaro recently and the production wheels had the bead roughed up, I don't think they used knurling, it was in one of their publicity vids...
Correct on the Camaro, the front tires under braking.
Old Jan 12, 2016 | 06:11 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
this is what i was talking about sand drag racers, we had alot of trouble keeping these seated with 3psi in them they would either spin or leak, or sometimes break the bead seal if you left and kicked the rear end out. it makes 125hp and with a centrifugal lockup clutch all the power is delivered to the gun drilled hollow axle with those .125 thickness light weight tires the shock load is very high.
https://lh3.googleusercontent.com/pK...i=w799-h599-no
but there are many scales of this problem we are not the only ones, alot of drag racers are using bead lock wheels or running screws into the tire to hold it still. I dont like the screw idea much
Old Jan 12, 2016 | 06:14 PM
Deuuuce's Avatar
LOL you're right, 125hp!! lol!
Old Feb 1, 2016 | 09:31 AM
olwe's Avatar
olwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of lightolwe is a glorious beacon of light
Reporting on the outcome of my most recent experiences from Sebring yesterday.
Actions taken in advance:
- Rims sand blasted where tires squeeze radially.
- New Hoosier R7 315/30-18's and 275/35-18's.
- Two tires mounted dry with alcohol only as lubricant, which evaporates.
- Two tires mounted using Permatex 80011 Form-A-Gasket #2 Sealant (on recommendation from drag racing friend).
- The two mounting methods were installed diagonally LF-RR and RF-LR.
Outcome:
- 160M on track.
- The two tires mounted with Permatex slid slightly in the beginning. I then switched them side to side and they slipped back closer to starting pos., but then seemed to no longer slip. One tire is about 1" off the mark, and the other one right on.
- The two tires mounted dry using alcohol only during mounting did not slip at all!
Choice for me going forward is simple: The glue is messy. The alcohol mounting is clean and did not slip, and will be what I use going forward. I don't know whether the sand blasting helped but assume it did. For the first time ever the tires did not go out of balance and I will not have to re-balance before going back!
Old Feb 1, 2016 | 09:46 AM
993GT's Avatar
Nice test and thanks for sharing the results!
Cheers,
Rob
Outcome:
- 160M on track.
Old Feb 1, 2016 | 06:06 PM
Deuuuce's Avatar
Interesting! Thanks!
Old Feb 1, 2016 | 10:50 PM
BLKMGK's Avatar
Not surprised, I've used methanol when putting on silicon sleeves for intercoolers and once dried it had to be pried off with a screwdriver it stuck so well! Clean the rubber and the wheel and then lube it with the alcohol, it should stick really well! Happy to hear you've found a potential solution!
Raider89
Nov 8, 2017 06:51 PM
Porsche246
Dec 17, 2015 08:21 AM
randyb
Dec 16, 2015 09:38 AM
Dpm7471
Dec 6, 2015 10:39 AM
