Which hose is this
Old Jan 14, 2016 | 08:51 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
Is it not just a loose hose?, ie. can't you just remove it? might just be my picture perspective...like someone just left a random hose in the engine bay...only thing it looks like is the coolant tank overflow drain hose
just saved the pics and used 'paint' to draw on them
Originally Posted by z06801
Yes you got the right one where it is split/tare where it hooks on to the hard. You can't see that one unless the air box is out. The other photo it connects right above the hose you highlighted. the one you did highlight is the coolant over that just kinda got pushed over. Really stupid question, How do you draw on photos that would have help me a lot
Old Jan 14, 2016 | 09:19 AM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
No not a loose hose I tried to highlight where it connects with the gold solid line. could it be a fuel return something? I tired to circle it with the retouch pen.
Old Jan 14, 2016 | 09:30 AM
993GT's Avatar
IIRC that's the connection to fuel line to fuel cooler...
Old Jan 14, 2016 | 09:43 AM
z06801's Avatar
So if that other end was leaking were its split, I would be spilling gas?
Old Jan 14, 2016 | 09:44 AM
993GT's Avatar
big time!
Old Jan 14, 2016 | 09:50 AM
993GT's Avatar
looking at earlier pictures again (last night was beer-fogged, lol), where is your coolant vent line?
Old Jan 14, 2016 | 09:51 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
The gold hard line you are showing the hose connected to, is typically the fuel return line (see the red circled tube in the drawing below).
I have seen it in a DYI for engine removal, when it looked exactly like your car (with no threaded fitting) and connected to another hard line on the chassis. My car, the pictures posted earlier by another member and the drawing below all show the line with threaded (hex) fittings.
Either way, I believe the hose you are pointing to in your drawing is a fuel line.
Later, Steve
Old Jan 14, 2016 | 09:52 AM
z06801's Avatar
big time!
Got it, Thanks for your help! I should get a small hose clamp below the split to keep it from getting worse until I can replace it. No signs of any leaking yet.
Old Jan 14, 2016 | 10:11 AM
z06801's Avatar
Later, Steve
That's weird it would be just a hose pushed on to a hard line with no clamps even that's why I thought it was some sort of vac line.
Old Jan 14, 2016 | 10:36 AM
It's a return line, so it wouldn't be as stressed. Still seems strange, but I have seen it like your car before.
Old Jan 14, 2016 | 06:44 PM
z06801's Avatar
It's a return line, so it wouldn't be as stressed. Still seems strange, but I have see. It like your car before.
Yep return line and I found it's not split rubber hose it's a solid line all the way though, it just has a rubber coating to protect it in the engine bay. So where it looks split it's not connected there but that just where the rubber coating stops.
Thanks for everyones effort trying to figure out what I was talking about.
Old Jan 14, 2016 | 08:43 PM
993GT's Avatar
that makes more sense, glad its figured out!
Cheers,
LC996
Jan 3, 2016 02:21 PM
EZ Cookin
Jan 2, 2016 03:30 PM
Slopeslider
Dec 29, 2015 09:30 PM
Ronny-
Dec 23, 2015 09:30 PM
Erik@RSC
Lamborghini Vendor Classifieds
Dec 17, 2015 12:26 PM
