Who is running Bilstein B8 shocks with H&R springs?
Old Sep 23, 2016 | 12:42 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
Originally Posted by splitime
Good deal, now to find who has the best deal on them.
Check AJ USA. AWE tuning also has decent pricing.
Old Sep 24, 2016 | 08:49 AM
Mat59's Avatar
Mat59 is just really niceMat59 is just really niceMat59 is just really niceMat59 is just really niceMat59 is just really nice
I was just about to post a question asking about B8's but noticed this thread. My stick ROW shocks are leaking so I'm considering a refresh or update. I'm not in the US so my car has the ROW suspension that already sits quite nicely - not much wheel arch gap. I was going to retain the original springs and go with B6 dampers but I am also considering some H&R springs with B8's.
Excuse the hijack, but what do you think I should go with? Is there a need to replace the springs assuming they are not cracked etc? Will the H&R springs lower it further than my ROW springs?
Old Sep 24, 2016 | 11:31 AM
vogz's Avatar
All depends on the ride height you want. If you are happy with your ROW ride height then as long as the springs aren't cracked or rusting badly, you can re-use them. Just purchase either new ROW dampers or the B6/B8 dampers (B8 damper with have a slightly firmer/sportier ride). If you want your car to be a little lower, then pick up the H&Rs with the B8 dampers. Perfect ride height IMO and really good ride and handling.
Old Sep 24, 2016 | 11:36 AM
Mat59's Avatar
Thanks. What is confusing me is that the H&R springs say that they lower by 25mm. Is this 25mm lower than US height or ROW? My ROW car is pretty low already and 25mm further would be 'slammed'. Don't want to lose the usability of the turbo. Have a BRZ for track duties.
Old Sep 24, 2016 | 12:55 PM
vogz's Avatar
25mm lower than US height.
My wheels/tires are almost an inch larger in diameter vs. the stock 18s and I still have a tiny gap between the fender and the top of the tire.
Old Oct 5, 2016 | 07:12 AM
splitime's Avatar
splitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond repute
So it appears that no one has the b8 rears in stock... grumble grumble back order grumble.
Old Oct 5, 2016 | 07:48 AM
vogz's Avatar
I ran into that too and they ended up shipping from AJUSA sooner than expected. They are worth waiting for IMO. If you want to check out the ride/handling on my car, let me know.
Old Oct 5, 2016 | 07:52 AM
splitime's Avatar
Already picked up fronts and tarret front top hats. Just need the rears, figured you guys wouldn't steer me wrong and started accumulating.
Old Oct 27, 2016 | 09:26 AM
2002Chris996's Avatar
2002Chris996 is infamous around these parts
Have been running on Bilstein B8 all summer. Great improvement over OEM. OEM had a floating feeling...not good. B8 are shorter than OEM. I am still getting front end rise on acceleration, more than desired. Just picked up H&R and will install.
BILSTEIN B8
Great Ride nice upgrade!
Old Oct 28, 2016 | 07:34 AM
TXTurbo996's Avatar
TXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud ofTXTurbo996 has much to be proud of
I'm also on B8's and H&R springs. The B8's are the equivalent to the M030 shocks, and the H&R springs are also roughly the same ride height, only about .25 to .5 inches lower, though I am not sure about how the spring rates compare to the M030 setup.
I had coilovers on other cars before and frankly I just didn't want to mess with them and just wanted a good handling solution with no fuss. The B8's and H&R springs meet that criteria perfectly.
Old Oct 29, 2016 | 01:07 PM
'02996ttx50's Avatar
^ agree on the combo, but mine on mo30's and h&r reds is lowered about -40mm. its pretty low but suits my canyon needs well. good to know the b8 is the contemporary equivalent, as that'd be my first choice when time to replace as well.
Old Oct 30, 2016 | 07:36 AM
TXTurbo996's Avatar
It's interesting, some websites say the H&R's give a 1.25" drop, some say 1.5", and I've seen some saying as much as 2".
For me, I think the rear is dropped about 1.5 and the front 1.25-1.5. I bought my car and they were already installed so I have no before/after comparison, only comparing with a friend's stock tt.
At any rate, the B8's with shorter springs go a long way towards improving the handling, but then again, my stock shocks had ~60k on them, so even a stock replacement would probably have been an improvement as well.
Old Oct 30, 2016 | 12:18 PM
yeah, mines about 1.5 lower..and iirc(?) that difference btw their lowering amount estimates could be the differential btw the various rates of the ( three, that i know of? ) options in lowering springs they offer for our platform. mine ( again ) are the red "sport" spring generally agreed to be the best mid-level compromise for a street driven car, and they do offer a full 1.5 inch drop. though the older they get, obviously, the more they will sag. the race springs aren't really optimal for a street driven car as they are at least a 2" drop.
Old Oct 30, 2016 | 05:06 PM
OK, PIC of H&R Springs with Bilstein B8. Was running stock springs with B8. What a vast improvement. Much more comfortable ride, more stable, no float, little if none front end rise on execration. Ride height is excellent, just enough to get out of incline driveway. DIY install. Did not remove any ball joints. Just disconnect front axel and remove strut. This is an excellent setup for street use.
BEFORE H&R
AFTER
[IMG] [/IMG]
[IMG] [/IMG]
[IMG] [/IMG]
Old Oct 30, 2016 | 07:50 PM
^ ride height in your "after" pics still look a bit high to me, but maybe it's the angle. speaking of high the front wheel arch looks as if what we used to call a three finger lid would fit in there lol. I'm sure the springs'll settle some, though.
