Are PCCB wheel clearances the same as non-PCCB?
Old Feb 20, 2016 | 07:01 AM
N2SPEED's Avatar
N2SPEED is infamous around these parts
Just trying to understand if the fitment for X-50 with PCCB and non PCCB are universal. It doesn't appear that there is any difference in OEM part numbers, but that doesn't necessarily answer the question. I just want to make sure that I won't have any clearance issues on aftermarket turbo wheels (known to fit on a non-PCCB), but mine has PCCB.
Old Feb 20, 2016 | 08:09 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
PCCB/yellow runs 350mm discs vs 330mm discs on 6TT with iron/red
Less wheel clearance with PCCB, but shouldn't have issue with any decent 18" options
Old Feb 20, 2016 | 12:42 PM
N2SPEED's Avatar
Thanks Rob, was looking to get a set of custom wheels, but they only have the measurements on the non PCCB. I never want to make assumptions.
Old Feb 20, 2016 | 03:12 PM
993GT's Avatar
Does the company have brake measurements for a 997tt? That will work for brake clearance purposes
Old Feb 20, 2016 | 09:45 PM
Dennis C's Avatar
That would work using 997 TT steel brakes, as they also have 350mm rotors. 997 TT PCCBs have 380mm rotors.
Old Feb 21, 2016 | 02:37 PM
N2SPEED's Avatar
Are the 997tt offsets the same as the 996 TT? I will call the vendor tomorrow. Sounds like they need to use the 997tt brake measurement.
Old Feb 21, 2016 | 08:54 PM
993GT's Avatar
different wheel offsets but the hub face/caliper relation is the same...if the spoke 'profile' fits a 997tt it'll fit a 996tt
Old Feb 21, 2016 | 10:27 PM
pwdrhound's Avatar
Might be easier if you share what wheels you are considering. Do you have a picture? I'm not aware of any 18s that would not fit the 997TT/996TTPCCB 350 brakes.
Old Feb 22, 2016 | 05:51 AM
N2SPEED's Avatar
They are Works Brombacher in 18". The wheels are custom order to fit, but they don't have the specs for 996tt with PCCB in their database.
http://www.workwheelsusa.com/product...y=38&wheel=104
From Works- "If the brakes are the same as the 996 GT2 with PCCB, then 18 inch would NOT
work (We have data on the 996 GT2)."
Old Feb 22, 2016 | 11:47 AM
pwdrhound's Avatar
Well, then it clearly won't work. The old school deep dish designs with a "lip" will limit spoke to caliper clearance as the spokes are positioned closer to the center of the wheel. I am assuming that you are looking at a 8.5" wheel. Do they have a 9" wheel available? 9" will be better than an 8.5 anyway if you are looking at running an 245 tire. See if they have an 18x9 ET40-45 in the wheel design you want. That would be ideal from a performance standpoint and give you the clearance you need.
Old Feb 22, 2016 | 02:40 PM
N2SPEED's Avatar
I have a new set of 18" tires, so really wanted to stay 18. The fronts are 225's, so a 9"rim would be pushing it. Sounds like I am going to need to make a compromise somewhere, by going with a different wheel design or move to 19's and buy new tires.
Thanks everyone for your help.
Old Feb 22, 2016 | 02:44 PM
pwdrhound's Avatar
Yeah, 225s are way too skinny for these cars... Go with a 235 or better a 245 for which a 9 is ideal
Old Feb 22, 2016 | 07:52 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
See if they can provide a template.
Old Feb 22, 2016 | 07:56 PM
993GT's Avatar
GT2/3 have a slightly lower offset disc(caliper closer to wheel)...might fit a TT...agree you need a template if they can't figure it out
Amiricanmade
Mar 11, 2019 03:15 PM
Fieldsport
20
Mar 2, 2017 08:14 AM
SilverBlue
May 6, 2016 06:43 PM
Triple7
Feb 3, 2016 10:54 AM
