Intermittent pas. window failure. HELP?
Old Mar 30, 2016 | 04:12 PM
dkfx's Avatar
dkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond reputedkfx has a reputation beyond repute
Hey guys,
Recently my passenger side window stopped working. It happened out of nowhere, and wasn't making any grinding noises before. Most people are pointing toward the regulator, but others have said to replace the switch.
It's been like for a week, but today it randomly worked momentarily. The window does not auto lower when the passenger door is opened.
Has anyone had this issue before or know where I can start? I don't want to just throw parts at it to fix it, but was hoping to find a troubleshooting tree.
Thanks in advance!!
Old Mar 30, 2016 | 04:16 PM
XLR82XS's Avatar
Does the window roll up and down or is it just the auto-lower function? Common failure point is the micro switch and/or door latch. On my 996TT I had to replace my driver side latch when I had the auto-lower go out.
Old Mar 30, 2016 | 04:21 PM
dkfx's Avatar
the auto up/down feature does not work at all.
the window hasn't worked for a week or so, then randomly started working again, then stopped.
How does one test for micro switch and/or door latch?
Old Mar 30, 2016 | 05:21 PM
XLR82XS's Avatar
I didnt test on my car. I bought the switch because it was only ~$20 bucks. Turned out to be the latch so then that repair came.
Sound like the random intermittent issue may just be the contacts in the switch giving up the ghost. I say replace the switch and see.
Old Mar 30, 2016 | 06:39 PM
'02996ttx50's Avatar
but my vote is for failing door latch mechanisms ( they are different L-R ) as opposed to window reg since no audble crunching is heard indicating failing window reg? GL..
Old Mar 31, 2016 | 08:46 AM
dkfx's Avatar
Guessing the $20 switch is a dealer part?
And the latch controls the auto up/down?
Old Mar 31, 2016 | 06:54 PM
XLR82XS's Avatar
Yep. Suncoast has them.
Old Apr 3, 2016 | 02:18 PM
dkfx's Avatar
How do i know if the motor or regulator is at fault.
Currently you can roll the window up and down... on the 3rd attempt it will fail, and just click. won't go up or go down. mess with it some more, and it will go up or down.
i've removed the door card and can't see anything really out of place, and not sure how to test the motor is intermittent or the regulator is intermittent. The auto / up down sounds like it's directly related to the micro switch ($30 suncoast part correct?) it sometimes works and sometimes doesn't. Very frustrating trying to troubleshoot.
Old Apr 3, 2016 | 03:19 PM
XLR82XS's Avatar
Sounds like motor if it works for a bit then clicks. You can always try swapping driver/passenger rocker switches and see if the problem moves to the other side.
Old Apr 3, 2016 | 03:47 PM
dkfx's Avatar
I tried that and nothing changed :/
Old Apr 3, 2016 | 08:35 PM
dkfx's Avatar
here's a link to the video showing what's happening.
The clicking you hear when the window not moving is me pressing the up / down switch and it stops working...only to start working a minute later...
https://goo.gl/photos/rohxDESxV7BMzXVCA
jerhofer
Jul 6, 2016 10:18 AM
solrac6262
Jun 18, 2016 09:49 AM
r6vr6
Mar 13, 2016 11:29 AM
zonnie
New Member Introductions
Feb 29, 2016 03:34 PM
zonnie
Cayenne 955/957
Feb 29, 2016 03:25 PM
