DIY Front diff oil change
as noted in this thread. 75/90 gear oil is what to use in the trans and front diff.. many use delvac 75/90 and i used to use redline 75/90 but switched upon install of an LSD to the delvac. for cars using an lsd ( modified ) there are strong admonitions against using any gear oil that has friction modifiers. but this is again only applicable if running an lsd.
this is the redline 75/90.
http://www.redlineoil.com/product.aspx?pid=47&pcid=7
here's the mobil 1 delvac. remember to ensure it's gl5 type which the synthetic 75/90 is.
https://mobildelvac.com/en/ancillary...hetic-gear-oil
EMC2
Apr 18, 2016 09:54 AM
