Tarret & Numeric cup style cables, opinions.
Old May 4, 2016 | 04:07 PM
  #31
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Just an update;
Had my linkages adjusted, they were out in both directions, side to side and forward and backward. Gear selection is now greatly improved, going into 2nd is much better but not quite as good as the rest of the other gear selection.
My indie seems to think my cables have stretched.
EDIT; He also mentioned that the plastic bits in the shifter have worn and have some play in them. He's a big fan of full metal cup shifter and cables.
I'm pretty happy the way it is. I need to draw the line somewhere with my spending, otherwise its money out the door...
Old May 4, 2016 | 07:23 PM
  #32
06Turbo's Avatar
06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future
There is always these https://phenixengineering.com/shop/p...t-bushing-kit/ I have yet to buy a pair for my 997ssk, but figured they may help with what slop you may be encountering
Old May 4, 2016 | 07:34 PM
  #33
JimTT's Avatar
That is excellent info, thanks.
Old May 4, 2016 | 11:55 PM
  #34
911mhawk's Avatar
911mhawk is infamous around these parts
I just did the Cup cables and they feel great, especially if you do motor and trans mount at the same time. Take the insulation off the stock ones with a razor and zip tie it tomthe Cup ones for a little vibration/noise reduction.
Old May 5, 2016 | 12:04 AM
  #35
JimTT's Avatar
Thanks.
My shifts are perfect now, 2nd is really good and much improved but seems like sometimes it just needs that little extra help and I'm hoping these billet shift bushings will fix that. They're on their way, I'll report back when fitted.
Old May 14, 2016 | 06:12 AM
  #36
mxracer's Avatar
mxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond reputemxracer has a reputation beyond repute
Hey Jim... just catching up after moving...
One other suggestion I'd offer up is the "8mm ball" fix that has it's own thread here. https://www.6speedonline.com/forums/...n-do-pics.html
Don't know what year your car is but I know my 01 didn't have the ball and when I installed it (actually I made a spacer on the lathe but same idea) it did make shifting feel more positive. Meaning when the gear is engaged it feels like it's ENGAGED not just slipped in.
Glad to hear you got things better. With the bushings, alignment and maybe the ball if should be much better.
Old May 14, 2016 | 06:29 AM
  #37
gt2rs's Avatar
gt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of lightgt2rs is a glorious beacon of light
I bought a set of numeric cables they worked for 2-3 shifts then they where toast. USP told me it was due to the fact that they where part of a test batch they promised me new ones but it took for ever to get the new cables. I would probably still be waiting for them if I didn't post my experience on this forum, that speeded up things. So in the end it was ok but I don't use them since I don't thrust the quality ..... all of course IMHO.
Old May 14, 2016 | 09:09 AM
  #38
'02996ttx50's Avatar
they sold you a TEST batch w/out disclosing it?! ^ incredible how the balance of *power* can shift ( sorry ) to the consumer with just some posts on the forums etc.
see vivid's recent jumping into the fray with their customer on that 4.0 stroker issue thread. it can be the great equalizer.
Old May 14, 2016 | 09:16 AM
  #39
911mhawk's Avatar
I was given the advice to always use Porsche parts in upgrading if possible because their stuff works and fits right. Can certainly cost a little more but after putting in a set of Cup cables I'm in no hurry to do it again.
Old May 14, 2016 | 01:00 PM
  #40
pwdrhound's Avatar
Never understood why people spend money on the imitation stuff when for a few extra bucks they can get the rear McCoy... It's extremely rare for the aftermarket stuff to be better than the factory parts. I've learned this over and over...
Old May 14, 2016 | 01:04 PM
  #41
mdurbahn's Avatar
mdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud ofmdurbahn has much to be proud of
X2 installing those cables sucked
Old May 14, 2016 | 01:24 PM
  #42
pwdrhound's Avatar
You gotta lube the hell out of the rubber grommet and bend the metal tab in the chassis back to make it pop in. Once you do that its actually not bad. I did it when the car was on the lift and it went on ok.
Old May 14, 2016 | 01:52 PM
  #43
911mhawk's Avatar
I got rid of a Numeric shifter that came with my car in favor of Porsche one because it wasn't really "better". Shorter throws don't make things better. BMW is similar, you can use their various shift rods to control the length of throw without buying an aftermarket one.
Old May 14, 2016 | 05:31 PM
  #44
JimTT's Avatar
Thanks again Dan, my car is an '04, I am going to try the spacer kit and see how that goes. I've a feeling this will fix it, for now anyway until the cables stretch even further and then it might have to be the cup cables.
Spacer kit left on the 5th but tracking only shows until 7th of may with no progress update.
As Mark said, this sounds a bit shady.
With your help I am starting to learn this thanks John.
That's unfortunate and a waste of money to the original purchaser. Thanks for posting and this just confirms what Johns trying to tell us.
Old May 16, 2016 | 11:03 AM
  #45
mxracer's Avatar
Originally Posted by icharde
Ira has been making top notch components for years, he's products are great quality and he stands behind them. He's always there to answer questions give him a call , super nice guy.
I have to agree... I bought a shifter and cables from another member (here of RL can't remember) and one of the cables was the old style that had issues. I called Numeric and explained my situation and they immediately sent out a new cable AT NO COST. As stated before it did make a big difference in the shifting of the car.
I don't agree with the "high and mighty" attitude of "factory only" either. If what was said above was true and Porsche made everything right the first time there would be no aftermarket for them and they would never have any issues. Hell Ruff wouldn't be in business either and maybe someone has bought a few Ruff parts???
