Instrument Cluster Repair options?
Old Apr 16, 2016 | 03:21 PM
spooltime's Avatar
spooltime is a jewel in the roughspooltime is a jewel in the roughspooltime is a jewel in the roughspooltime is a jewel in the rough
My recently acquired 996TT was missing the clock reset **** on the instrument cluster when I bought it, so I purchased a replacement set of *****. They arrived in the mail today so I went out to install the missing ****.
The new **** would not install, so I put a flashlight on it, removed the trip odometer reset **** for comparison, and immediately realized that it was just a missing ****; the actual shaft the **** slides onto was broken off.
So what are my repair options given this? Do I attempt to carefully JBWeld the new **** to the broken shaft, or should I be thinking about acquiring a salvage cluster to obtain a replacement **** shaft to replace my broken one? As it is, I currently cannot set the clock to the correct time.
Advice, please.
Old Apr 16, 2016 | 05:32 PM
jpflip's Avatar
Take a look at this thread especially a member called Qmulus....
http://www.renntech.org/forums/topic...er#entry264064
Old Apr 16, 2016 | 06:04 PM
'02996ttx50's Avatar
if it becomes serious enough? this place will rebuild the entire cluster to oem spec
http://www.nhspeedometer.com
Old Apr 16, 2016 | 06:44 PM
32krazy!'s Avatar
I did this repair and its not hard but patience us needed. Look on ebay for a broken manual boxster cluster. here the thread that shows how to disassemble the cluster.
https://www.6speedonline.com/forums/...or-change.html
Old Apr 16, 2016 | 06:45 PM
jtt99's Avatar
jtt99 is infamous around these parts
I had the exact same thing when I purchased my TT. I ordered a new **** and then found the original broken **** was in the glove box. I did what you suggest using gel super glue holding it in place with masking tape to cure. That was almost three years ago and it is still in place but I am real easy in any use of it. It did do some research before I repaired it and found that some others have been able to replace the whole shaft by getting one from a used Boxster cluster (the early ones are the cheapest on EBay). The only issue with this approach is having to remove the cluster and disassemble. Good luck!
Old Apr 16, 2016 | 06:48 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
I also went the super glue route for my clock stalk and it has held up for 4 years no problem. Of course, I only touch it twice a year anyway
Old Apr 17, 2016 | 01:23 PM
spooltime's Avatar
I did some further searching on the forums and discovered that a guy had a mold made of the plastic stems that break and sells replacement stems (which are unavailable from Porsche). Looks like the fix is remove the cluster, open it up, and replace the broken stem.
Here's a link to the part on eBay for anyone else wanting to replace the broken stem instead of gluing it:
http://www.ebay.com/itm/161945821194?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Apr 17, 2016 | 03:27 PM
32krazy!'s Avatar
PORSCHE INSTRUMENT CLUSTER SHAFT stalk reset stem clock odometer control
well they are proud of that piece of plastic!! 44$ for EACH stem!!! like i said i found a boxster cluster for 50$. the disassembly will likely brea a dial pointer or 2 so using the cluster gives you extra pieces oif your carefull
Wildcat1212
Jul 24, 2024 06:23 PM
gtron
Mar 3, 2020 02:00 PM
18ri
Cayenne 958
20
Oct 2, 2016 12:42 PM
Jeff_335i
Apr 8, 2016 09:22 PM
acs370
Apr 3, 2016 10:48 PM
