Pumping fuel failure
Old Jul 3, 2016 | 08:55 PM
SharkyShark20's Avatar
SharkyShark20 is infamous around these parts
Hey guys!
So heres my issue pretty much i try to pump gas into the car and it just shoots the gas right back at me. I try giving the car gas slowly and i mean slowly and after a little bit it'll shoot it right back at me. Theres not CEL on. No leaks that i can see when i look at the car.
Now I've had rats in my garage, which might be the issue but i haven't seen anything like leaks. I haven't followed the fuel line through but i did stick a wire through and it was going the whole way until i believe the line turns. Other than that I've never had this issue before and would like to ask our opinion before i decide to take it into the shop. Im pretty handy so anyone have any recommendations before i either take it to the shop or take the whole under panel out?
Thanks so much
Kris
Old Jul 3, 2016 | 09:12 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Had this happen one time to me. Here's the step.....
Put the gas nozzle reverse so its upside down that should take care of it. I forgot why this happens.
Old Jul 3, 2016 | 09:24 PM
Porschetech3's Avatar
Porschetech3 is infamous around these partsPorschetech3 is infamous around these parts
Sounds like your fuel tank vent has become inoperative. Could be from the rodent nibbling a wire into. There is a magnetic switch on the side of the filler neck that activates when the fuel nozzle is inserted. The magnetic switch sends power to a vent valve that vents the tank and allows for quicker refueling. If you take a screw driver and insert into filler and push small door open you should be able to hear a very faint click of the vent valve. Possible fault causes are blown fuse, faulty vent valve, faulty magnetic switch, rodent ate your wiring..lol
Old Jul 3, 2016 | 11:20 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Yeah just pressure.. Not a rodent lol.
DOPE_996tt
Mar 26, 2017 05:42 PM
GT650-25
Apr 18, 2016 09:51 AM
SimonB
Apr 11, 2016 02:45 PM
