997 S TPC supercharged having issues. Please help guys
Old Apr 5, 2016 | 11:34 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
Hey guys. My 911 just started giving me problems.
When I take off I can hear the supercharger then after 3k rpm my car feels like it's in limp mode. No boost at all. The boost gauge stays steady so there's no boost leaks. Do you guys have an idea of what's wrong?
We originally thought it was a misfire so we replaced the plugs. Still no change.
Any help would be appreciated.
Old Apr 5, 2016 | 07:55 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Hey,
I can certainly help, but I need more information. Where is the boost sensor located? It should be immediately before (as the air goes) the throttle body. Where does your boost gauge measure boost? When you saw "limp mode" what do you mean? How many PSI/ Bar are you seeing?
I'm guessing there's a clamp off, but tell me more, and send me detailed photos of your engine bay.
CATTMAN
Old Apr 6, 2016 | 05:44 PM
tphan's Avatar
tphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond repute
sound like she has a big leak...somewhere. Make sure all hose clamps are tight.
Old Apr 8, 2016 | 11:18 PM
abq997's Avatar
abq997 is infamous around these parts
Stupid question, but if there was a big leak, wouldn't he see a drop in intake pressure?
Old Apr 9, 2016 | 07:21 AM
tphan's Avatar
You are correct, there are lot of missing information here to diagnose the problem.
- what exactly is "Limp mode"? hesistate, sputter, detonate, backfire, etc...
- "No boost at all" at low rpm or WOT?
- "Boost gauge stay steady" this contradict to "no boost", doubt a centrifugal supercharge would be at full boost at 3,000 rpm. Steady could mean at vacuum or pressurized. What is expected boost of the setup?
Not enough info.
Old Apr 9, 2016 | 09:18 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Seems like giving TPC a call would've my first step.
Old Apr 10, 2016 | 02:24 AM
MrPrice's Avatar
MrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud ofMrPrice has much to be proud of
I have a different kit in my car, but you might want to check the air filter.
Old Apr 11, 2016 | 08:42 PM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
Yeah, that is what I would do, Tom Chan is very knowledgeable and helpful.
Old Apr 13, 2016 | 08:57 AM
Macster's Avatar
If boost stays steady and power falls that reads like the DME is pullng timing, big time, probably to save the engine from detonation.
You might be able to see this if you were data logging engine telemetry.
Are you running too much boost?
Are the plugs/coils good?
Fuel supply good? Fuel pressure good?
Have you confirmed the AFR are good at all engine speeds/loads?
Do you have a "hot air intake" mod? (Exposed air filter in the engine compartment so the engine gets engine compartment -- and heated -- air rather than cooler air.)
MadWhip
Apr 3, 2022 06:16 PM
sinKing
Jun 6, 2017 05:41 PM
r_matt_6
Sep 20, 2016 01:38 PM
SeattleTurbo
Mar 8, 2016 08:19 AM
