questions of my 996 turbo
Old Aug 11, 2016 | 04:20 AM
samugtmadrid's Avatar
samugtmadrid is infamous around these parts
Hello friends, I have a porsche 996 turbo, and I entered presentations in this forum, I'm slowly making him preparations and a few days ago I bought a Y-pipe, then hang pictures of my car and what I bought, I have to look how.
I have several questions because the y-pipe is very large and I have to remove the filter box, they told me I have to put 2 filters K & N RC-9630 and be put straight to the turbos, I've seen pictures buestras and see that poneis a dejais pipes and the filter above the intercooler, someone can tell me those measures tunberias? someone sells some?
on the other hand do not quite understand, I have to do with the MAF sensor? because if I remove the air filter box not know what to do and I'm afraid I error, I have read a Ford MAF sensor sets, but what?
Thanks and now will try to put pictures of my car !!!
sorry for my English, I'm from Spain
This is the y-pype, i see i not have the hoses to intercoolers i dont know if i can put silicon forge to intercooler
Old Aug 11, 2016 | 09:55 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
You're missing some parts there to complete the y-pipe setup. That looks like a Markski brand y-pipe...check it:
https://markskituning.com/product/ma...pe-intake-kit/
Yes you will need to remove the factory airbox and maf setup. Running filters off the turbochargers is probably the easiest thing to do. Markski might have some fender intakes you can purchase from him...maybe even the rest of the kit along with the MAF sensor. Good luck man! Nice car!
Old Aug 11, 2016 | 11:40 AM
Smile
thank you very much for answering, the hoses going to do the traditional way, the most difficult was the y-pipe and I have it, the rest will do my mechanic and I will buy the filters to K & N
the problem is the MAF sensor, the seller told me he did not need to put the sensor, it was not necessary, is it? I have to put the sensor? They sell on ebay? I've looked but not what is.
Old Aug 11, 2016 | 02:43 PM
03EvoIII's Avatar
Nah you don't need it. Just need a mafless tune.
Old Aug 11, 2016 | 03:49 PM
Sorry friend, but i dont know that what is a mafless tune ; have a link to buy?
Old Aug 11, 2016 | 03:54 PM
Maflees is It is to modify parameters of the car? Is complicated?
i can run my oem maf sensor in stock location ?? is less complicated i think
Old Aug 11, 2016 | 10:05 PM
BLKMGK's Avatar
Yes, the computer must be modified to run without the MAF sensor. A COBB dealer, Markski, and others can do this.
I don't have the dimensions for filters on the turbos but if you do this you will also want rain socks. Another option would be to run fender inlets which place filters near the intercoolers, these are often custom built.
What other modifications have you made? If you have not already made other performance changes you may want to wait before upgrading the y-pipe as there are other restrictions that that should be upgraded before that piece becomes a restriction.
Old Aug 12, 2016 | 03:19 AM
Thanks!!!
if i buy a Ford maf I do not need to do anything else? ford model that I have to buy it? Is type " plug and play"?
I have only exhaust and collectors.
Old Aug 12, 2016 | 03:34 AM
Originally Posted by samugtmadrid
Thanks!!!
Is this? But what model of ford?
I think is this:
Afh55 but i dont know because have more numbers, afh55-m10, m13....
Is this?
Old Aug 12, 2016 | 10:32 AM
BLKMGK's Avatar
Ah, that DOES look like its but to accept a different MAF sensor! I'm not sure which sensor it takes but I'm pretty sure it will still need to have ECU modifications made. Marski is likely the guy you will want to talk to. He has done tunes for cars overseas before and should be able to help you out. Do you have a Durametric cable? What other modifications have you made?
gtron
Mar 3, 2020 02:00 PM
phantom works
Mar 25, 2016 02:03 PM
rspiteri
Aug 29, 2007 08:07 PM
DJ
Jul 19, 2003 08:24 PM
PN-
Jul 18, 2003 10:14 AM
