What shifter is this?
Old Oct 6, 2016 | 02:46 PM
rennteche55's Avatar
rennteche55 is infamous around these parts
So I pulled my console off today to get painted and I took a look at my shifter and this is the part number on the base of it. So I'm assuming it's out of a 997? Anyone know which model?
Old Oct 6, 2016 | 02:55 PM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Google says regular 997 shifter. If that is correct and IIRC, more or less the same as the GT3 shifter but with plastic bushings rather than metal.
Old Oct 7, 2016 | 12:53 AM
So would there be any benefit to going to a 996 Short throw shifter?
Old Oct 7, 2016 | 05:42 AM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
If you are going to make a change, go with the 997 ssk or an aftermarket one - everybody seems to love Numeric.
Old Oct 7, 2016 | 10:28 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
If I were you, I would just update what you have to use metal bushings. The 997.2 GT3 shifter is arguably one of the best and by adding the metal bushings that is what you would have, and it would maybe be cheaper than buying a whole new unit.
Shifters are so subjective though, maybe best to try a few different ones in local cars.
Old Oct 7, 2016 | 03:21 PM
VAGscum's Avatar
The 996 over the counter short shifter is a reboxed B&M which is garbage. The best options are the 997GT3 or the 996 cup shifter.
Old Oct 8, 2016 | 12:51 AM
Bahnburner's Avatar
Bahnburner is just really niceBahnburner is just really niceBahnburner is just really niceBahnburner is just really niceBahnburner is just really nice
997.2 SSK with Function First Shift Right.<br/>Works just fine.
Old Oct 8, 2016 | 01:24 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
+1 for Luka and his shift right soloution
Old Oct 8, 2016 | 04:52 PM
What exactly is the "shift right" solution?
Old Oct 9, 2016 | 02:03 AM
timccloud's Avatar
Rifle bolt shifter upgrade best thing you can do to your shifter.
http://www.function-first.com/produc...right-solution
Old Oct 10, 2016 | 10:12 AM
It is the mod to add those metal bushings as I mentioned earlier in the thread. Basically makes it the same to the 997,2 GT3 shifter
Old Oct 10, 2016 | 10:25 AM
pwdrhound's Avatar
Factory Porsche Motorsport 996Cup shifter + Cup cables + Cup selector lever = perfection.
Simple uncomplicated race proven set up that just plain works.
For a simple swap of just the shifter, the OEM 997SSK is very good albeit a little plasticky. For daily driver use it's a great choice and will not add any noise
semicycler
Sep 19, 2016 10:09 AM
miamiadjuster
Sep 17, 2016 06:12 AM
