My car Vs 991.2 TT-S w/ catless exhaust, tune and intake
Old Mar 1, 2017 | 10:27 AM
  #136
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
So whats the point of me posting dyno numbers if they're just going to be discredited? Not worth my time and money if it means nothing.
Old Mar 1, 2017 | 10:33 AM
  #137
BauerR's Avatar
Originally Posted by brnrdtns
Lets talk here it terms of X turbocharger with a stock 996tt block with all or most bolt ons. Based on those factors your numbers seem optimistic at least based on the posts I've seen here, I have not dyno'd my car at all yet.
Noone here has my level of mods on stock K16's. We are in uncharted territory.
I will dyno but not sure if I feel like dealing with the headache of posting it here.
Old Mar 1, 2017 | 10:37 AM
  #138
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Say Bauer is making around 450 wheel and could push that to 470-480 with a 5 bar and good gas seems reasonable to me. Some of the above assumptions seem optimistic based on dyno numbers I've seen people post through the last 5 years here. I know my 18G billets are only supposed to flow 43 lb/min so I don't think the 16's flow that much.
Bernard I'm again talking turbocharger flow. New gen billet 16g from blouch is a 41lb wheel.
http://www.bptstore.com/Subaru-WRXSTi-TD05H-16G-XT-Turbocharger_p_23.html
you can't compare turbos from 5-10 years ago to stuff today. Tech has come so far it's crazy. Even a billet wheel to billet wheel of the same size. One from today very well may flow 5-10% more air than the old design billet wheel from 5 years ago.
I'm talking with what currently availbe produced today.
  #139
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I'd guess you're getting 15-20 hp from the intake mods, certainly there is even more benefit lower in the power range that helps the car pick up faster that would be really noticeable. That's pretty good for intake mods though, HP is hard to come by without using tons of boost or porting out heads with cams and stuff like that.
Old Mar 1, 2017 | 10:42 AM
  #140
brnrdtns's Avatar
http://www.bptstore.com/Subaru-WRXST...rger_p_23.html
Ok, then it would be fair to compare the new 16g to the old 18g, which has done 730 wheel hp or so.
Old Mar 1, 2017 | 10:45 AM
  #141
BauerR's Avatar
Catless and mufflerless 3" exhaust picks up a bunch. Blowing through 4 mufflers is a restriction any way you look at it. 4.5" intercoolers with proper 2.5" plumbing and not the restrictive "bolt-on" style end tanks also pickup flow.
The filters on turbos made the biggest "feel of pants" difference on my car to date. The difference felt ridiculous.
Old Mar 1, 2017 | 10:47 AM
  #142
flewis763's Avatar
Here is another example of turbo tech coming a long ways. Here is the 71hta comp wheel.
the inducer is .7mm larger than an 18g and 1.3mm smaller than a 20g with the same exducer size as both. It flows 51lb.
http://www.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Cod e=FPEVO971CHRA&Category_Code=Lancer-Turbo
Old Mar 1, 2017 | 11:02 AM
  #143
brnrdtns's Avatar
http://www.forcedperformance.net/mer...e=Lancer-Turbo
Nice. Is there any tradeoff for spool up time?
Old Mar 1, 2017 | 11:12 AM
  #144
flewis763's Avatar
was that cast or a billet. A mhi cast 18g flows about 39lb. So a modern billet 16g out flow a cast 18g by about 5%. Looking at something like a cast 20g, they flowed 42lb. Modern billet flows over 50lb.
billet to billet it can be hard to say as it harder to find maps for everything.
Old Mar 1, 2017 | 11:14 AM
  #145
flewis763's Avatar
it would spoil faster. More efficient design as well as probably lighter than a cast 18g or 20g.
Old Mar 1, 2017 | 11:55 AM
  #146
flewis763's Avatar
Here is any example of technology. This is garrets 3071 gtx wheel, gen 1 vs gen 2. You can see how much flow is gained. Same size wheel, just better design
Old Mar 1, 2017 | 06:55 PM
  #147
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
I agree, I think dyno would just get people arguing more. Unless it was a known dyno where some other cars have posted up numbers to compare.
I'd rather see some 60-130 vbox numbers. To compare with the other 60-130's listed on here. Even that would probably not be argument free but it'd be cool to see some solid 60-130's from your setup.
Old Mar 1, 2017 | 06:58 PM
  #148
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
No ones arguing you said you can make 530awhp on stock k16. So we all wanted to see it. 60-130 will be around the 9s with stock turbos on a tune.
Take a video with the speedo of you flooring it then we can tell better.
Old Mar 1, 2017 | 07:22 PM
  #149
gophaster's Avatar
Does anyone near BauerR have a vbox they could lend him? I think seeing a couple (2-3) consistent vbox runs would really be a great barometer here. Honestly, I believe that would really be the best bet.
Old Mar 1, 2017 | 08:21 PM
  #150
996tt550hp's Avatar
Lol level of mods? You have intercoolers, y pipe, TB and plenum. Those mods make a tad of hp if any on those stock k16s.
