Filters on turbos
Old Feb 25, 2017 | 11:33 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by BauerR
I don't drive my car enough to worry about grime. (Maybe 1500 a year)
After 800 miles I had a lot of dirt on my filters.
Old Feb 26, 2017 | 08:09 AM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
You need to minimum r in socks on the filters to keep most of the water and large dirt out. I will be making splash shields for my setups that connect to the toe arm
Old Feb 26, 2017 | 08:21 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
I'm about 600 miles on mine and everything looks like new. However, if the shields are something you want to market and sell, count me in for a set.
Old Feb 26, 2017 | 08:25 AM
996tt550hp's Avatar
QUOTE=flewis763;4611629]You need to minimum r in socks on the filters to keep most of the water and large dirt out. I will be making splash shields for my setups that connect to the toe arm
I'm about 600 miles on mine and everything looks like new. However, if the shields are something you want to market and sell, count me in for a set.[/QUOTE]
I have ran in rain with the socks on and poured water on the sock and the filter was still dry. You don't need splash guards.
Old Feb 26, 2017 | 08:35 AM
flewis763's Avatar
Splash guard protects against water but the biggest reason for it it to prevents rocks from getting thrown up and damaging the filters. Something very simple to make but probably only work with the filters I use.
Old Feb 26, 2017 | 08:39 AM
BauerR's Avatar
My car doesn't see rain and only goes out on sunny days but I agree. You can't be too safe with road debris
Old Feb 26, 2017 | 08:40 AM
996tt550hp's Avatar
I have had them on for a year no damage at all. You don't want to limit the air that gets to the filter. Whatever works hehe.
Old Feb 26, 2017 | 12:25 PM
flewis763's Avatar
well I drive one roads that are probably a lot worse than you. It won't limit flow any. I also run a larger filter than most. 4.5×6.5 inch filters.
Old Feb 26, 2017 | 02:41 PM
996tt550hp's Avatar
That's good I have the size that fits for our cars at home. Anything bigger will hit the suspension.
Old Feb 26, 2017 | 04:05 PM
Kerma996's Avatar
Kerma996 is infamous around these parts
Do you mafless guys experience fuel issues at altitude? I don't know how mafless fuel programing is accomplished. Without "O2-in" information how is the fuel calculation (or look up table) accurate?
Old Feb 26, 2017 | 06:48 PM
G-Rat's Avatar
G-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to behold
I'm ay 5,000 ft. No fuel issues running MAFless.
But I think if I went to sea level, I would need to retune to be safe.
Old Feb 26, 2017 | 11:05 PM
BLKMGK's Avatar
MAP sensor will "see" altitude just fine, it's designed to measure pressure after all...
Old Feb 27, 2017 | 11:10 AM
msv's Avatar
msv
msv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to beholdmsv is a splendid one to behold
For those guys who have filters on the turbos, would you mind sharing the brand/part number and any pictures? Thanks in advance.
Old Feb 27, 2017 | 11:16 AM
r0nd3L's Avatar
r0nd3L is infamous around these parts
It would be great if somebody created a new thread with information such as part numbers.
Personally, I'll probably be placing my filters above intercoolers with DIY, so if I go that route, I'll definitely post details and what parts are needed.
Old Feb 27, 2017 | 11:20 AM
G-Rat's Avatar
These are what I'm running directly on stock K24s. Different turbos may have different inlet sizes.
