Filters on turbos
Old Mar 2, 2017 | 08:21 AM
  #61
G-Rat's Avatar
G-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to beholdG-Rat is a splendid one to behold
I would like to mention one more aspect on the potential gains of filters on turbos. This experience is most likely due to being at 4500 ft elevation, but could be relevant to others as well.
On my stock K24 X50 car, running SRM intercoolers, Markski 3" catless xpipe, Markski tune and upgraded wastegate actuators, I could not run more than 1.0-1.1 bar at peak, and it would generally peak around 4500 rpm in third gear and drop to 0.9-1.0 bar at redline. First and second were even worse, 0.7-0.8 bar at best. I tried and tried, even tightened the wastegate actuators to only crack at 17 psi, still wouldn't hold.
Switched to filters on turbos and instantly was able to hit 1.3 bar at 4500 rpm and hold to redline in third gear. First and second were also seeing 1.1 bar.
So as others have mentioned, maybe 20-25 hp from switching to filters on turbos (assuming same boost). But in my case, I was able to build another 3 psi of boost. I think this is why I saw a 40hp difference on the same dyno after filters on turbos.
Old Mar 2, 2017 | 09:16 PM
  #62
Pacileo01TT's Avatar
Pacileo01TT is a name known to allPacileo01TT is a name known to allPacileo01TT is a name known to allPacileo01TT is a name known to allPacileo01TT is a name known to allPacileo01TT is a name known to all
Originally Posted by John@SpeedTech
I will second a finding of no performance gains with fender intakes vs. our SpeedTech Hi-Flow intake plenum/hard piping behind the motor. I installed fender well intakes on my car many years ago and went back to hi-flow pipes for a few reasons. We also dynoed before and after and did 1/4 mile runs before and after. No change in performance. I did enjoy the BOV vent to atmosphere sound, though.
Good info John! When I finally get to my k16 billets (next winter) I'll be reaching out to you for intake plenum hard plumbing. I'll be needing to upgrade to a Sachs 2.5- so I'll be in there anyway. It makes sense for a simple k16 billet swap, that it would provide more than sufficient flow and the goals I'm trying to achieve with the driveability rain or shine. Definitely some cool results here though- some impressive #s from Grat. Finally going to get my 3" X Pipe on Sat.- be on the lookout for some photos! Such an awesome unit, thanks again! -Chris
Old Mar 3, 2017 | 12:56 PM
  #63
Kerma996's Avatar
Kerma996 is infamous around these parts
Do you have a photo of your hi-flow plumbing installed?
Old Mar 3, 2017 | 04:11 PM
  #64
John@SpeedTech's Avatar
Here are a few pictures of our Hi-Flow plenum with hard piping. This is a no compromise solution for long term reliability, now tested for 10 years/100,000 miles with no sign of wear or failure on the hard pipes:
Our 2.5" x 75mm Y-Pipe on the pressurized side completes the full 2.5" Hi-Flow path (there are SpeedTech 2.5" in/out intercoolers installed to match the flow):
* Our Y-Pipe is also available with diverter valve vent tube delete and Tial BOV's on the back side.
We are currently finishing one with a beautiful satin black wrinkle finish with two Tial BOV's, one on the rear of each leg where the air box normally sits.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Mar 6, 2017 | 08:15 AM
  #65
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Its way better to use a bendable or hard piping instead of filters on turbos.
What about rainy days? Thunderstorms, wet roads?
Old Mar 6, 2017 | 08:28 AM
  #66
r0nd3L's Avatar
r0nd3L is infamous around these parts
This is pretty interesting if you haven't seen the filters covers/wraps in action. Personally, I didn't expect them to work as good as shown in the video, so it's a nice surprise.
Obviously, it won't protect from everything, but definitely seem to provide a lot of benefit.
Old Mar 6, 2017 | 08:49 AM
  #67
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
The socks really do an amazing job at keeping water out. I'm building splash guards for mine this year to help from big splashes of driving through a puddle.
tuning to the stock box though is a great option and for guys dd the car in all conditions it's probably better.
Old Mar 6, 2017 | 11:26 AM
  #68
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
https://www.youtube.com/watch?v=IQPzEy5Sapw
https://www.youtube.com/watch?v=wXRqbvck_D4
i like to see this test under full load (during the turbo sucks 40lbs/min
Old Mar 6, 2017 | 11:56 AM
  #69
SamboTT@ByDesign's Avatar
IMO it's not for everyone and not all conditions. There is a good reason for all the other alternatives. But if you have the whether and are ok with the maintenance we know it works with some minimal risk.
Old Mar 6, 2017 | 02:42 PM
  #70
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Why would you be driving full song, in the rain, under those conditions? Or on recently wet roads?
Old Mar 6, 2017 | 05:43 PM
  #71
ccjimmyb's Avatar
ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !
Originally Posted by BauerR
Why would you be driving full load, in the rain, under those conditions? Or on recently wet roads?
THIS ^^^^^^^^^^^^^^^
Old Mar 6, 2017 | 06:36 PM
  #72
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
I was going to ask the same thing, lol
Old Mar 6, 2017 | 09:08 PM
  #73
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
For those interested in buying the parts you can get the filters and hydrophobic prefilters from AdvanceAuto using coupon codes for about $100.
I'm looking forward to trying this out and hearing more turbo noises.
Old Mar 7, 2017 | 06:01 AM
  #74
winnigt2's Avatar
why not in the rain ?
second.....
to hold a fiat panda behind you..... and for my understanding a engine sucks air all over the time..
its not black and white , between this conditions are many colors
Old Mar 7, 2017 | 09:00 AM
  #75
Guys make sure you log and have you car/tune looked over as almost every one I've seen needs more fuel.
