996 GT2/3 lower control arms
Old Jul 3, 2017 | 03:53 PM
pwdrhound's Avatar
Originally Posted by stv951
Any benefits from using GT2/3 LCA on the street car ?
I rarely go to the track with my 6TTC hence i guess i wont need so much camber
No benefit unless you need more camber.
Old Jul 4, 2017 | 03:29 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
For the street i wouldnt do it either, since its not necessary for going fast in a straight line.
Old Mar 31, 2020 | 07:51 AM
dcruz90's Avatar
dcruz90 is infamous around these partsdcruz90 is infamous around these parts
ghostofpain,
Do i need the 10mm driveshaft spacers if I'm retaining awd in the front?
I ordered (2) front GT3 LCAs to replace my stock arms with 7mm of shims. I am not planning on tracking the car at the moment so I am looking to retain OEM alignment settings or at least go to GT2 settings.
Old Mar 31, 2020 | 11:35 AM
GT3 Chuck's Avatar
Administrator
3 yr old thread...you may not get an answer
Old Mar 31, 2020 | 12:56 PM
dcruz90's Avatar
It's alright, I think I've come to the conclusion that if I don't use the shims I will retain the OEM LCA spacing. Even with 7mm of shims I don't think I will need the 10mm axle spacer.
I need to figure out what my car's factory alignment settings are and have the alignment shop add in the shims as necessary.
surahman1
Jul 10, 2017 12:46 PM
porsche996tt_tpe
Aug 21, 2014 07:26 AM
landjet
Aug 4, 2009 01:55 PM
luiscarlos
Dec 26, 2008 07:41 PM
rosesplus
Feb 21, 2008 02:43 PM
