Durametric question
Old Mar 12, 2018 | 03:08 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Durametric question
Can the Durametric turn off the brake wear CEL permanently? My brake pads are fine but that light keeps coming on. I have the cable but don't see the option....if it is an option.
Old Mar 12, 2018 | 03:18 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
I do not believe it can however you can jumper out your sensors at each wheel. i have my fronts jumpered out as i was unable to find the sensors for the Brembo GT 6 pot pads in the front.
I also have a full set of new stock sensors i will give you for postage.
Old Mar 12, 2018 | 05:08 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
+1. Mine are taped to the axles...
Old Mar 12, 2018 | 06:07 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
can tie the sensors/harness away(assuming it is functioning/unbroken) or can jumper the wires.
Old Mar 13, 2018 | 12:28 PM
Third-Reef's Avatar
Chop the wires off about 2" from the connector on the back of the strut (on the wheel sensor side). strip the ends back and twist together. Tape it up, trim the loose end off the cable coming from the brake caliper so it does not flap around. This should make your light go off.
Old Mar 13, 2018 | 04:41 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
I'm pretty sure it can't.
Here is the Durametric site which lists coding abilities: http://durametric.com/modelfeaturematrixv6.aspx#coding
Old Mar 13, 2018 | 05:02 PM
993GT's Avatar
very little coding can be done for 996
Old Mar 14, 2018 | 11:25 AM
VGLNTE1's Avatar
awesome. Thanks!
Old Apr 20, 2018 | 09:11 PM
negb's Avatar
negb is infamous around these parts
Is there any way using Durametric (or PIWIS) or any other aftermarket scanner to see how many times Launch Control was in use on particular Porsche car ?
dus10r
Feb 19, 2012 04:41 PM
Nor Cal Turbo
May 9, 2011 02:06 PM
Merlin
Oct 7, 2009 06:33 PM
Ian_UK1
Feb 27, 2009 11:35 AM
$manager
Feb 25, 2008 10:15 PM
