Loss of power on track today
Old May 20, 2018 | 06:06 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
I was at Watkins glen this weekend, I was coming out of turn one entering the esses, suddenly under mid throttle my engine cut all power and dropped to idle. I had to go 4 off into the grass to be safe. I shut off the car and restarted, and it was completely normal the rest of the weekend. I had a code that said something about fuel, but in my frantic state sitting in the grass on track I accidentally deleted the code as the flagger was sending me back on track.
Any ideas? I'd like to prevent this from occurring again.
Old May 20, 2018 | 07:10 PM
eds996tt's Avatar
eds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of light
You encountered this in the start of the event and then it went away for the rest of your time there right ? Same thing happened to me same place and was fine after that. Sometimes when a injector hic cups this happens. Sends the ecu into a frenzy. This only ever happened to me once. I only use the care on the track and my car is always serviced before i go out. This happened right after plugs and coils new fuel filter. I also asked why it went into fail safe. I'm told it happens and my car only has 25 k on it. Never happened sense. Perhaps keep an eye on it.
Do you have new plugs and coils ?
Old May 20, 2018 | 07:16 PM
jdexter's Avatar
No. I did new everything (plugs, coils, filters) at about 13k miles, it's at 18k now. No recurring codes, ran perfect the rest of the weekend all the way to redline...
Old May 22, 2018 | 10:34 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
sounds like a fuel pressure issue, loss of it and bam, dead
check fuel pump, relays, etc.
mine went on my 996 with (at the time, 14k miles on her), so they just go.
Old May 22, 2018 | 10:35 AM
OP, what kind of fuel setup are you running? 5bar? injectors? new pump? i see your tuned
Old May 22, 2018 | 11:57 AM
jdexter's Avatar
markski tuned on his flow matched injectors... oem pump. I had my tune dialed back to 1bar on track. The rest of the weekend it ran great all the way to redline, so I assume if it was a pump issue it would come back. My best guess is MAF sensor got crazy and threw my car into limp. I'm not sure what else goes away with a reboot.
Old Jun 28, 2018 | 01:58 PM
yea the pump will start to whine then die or just die. sounds like a MAF, i'd clean it, dry it and give it another go. Maybe a new one if need be. Keep us updated
Headdoc
Feb 2, 2007 12:17 AM
steve harris
Jun 25, 2006 11:19 PM
mitchmarket
Apr 11, 2006 10:12 PM
mikescg
Oct 30, 2005 08:18 AM
bond
May 7, 2004 09:52 PM
