Should I drop the engine?
Old Aug 22, 2018 | 09:58 AM
ktr6's Avatar
ktr6 is infamous around these parts
Looking for some wisdom, I have an 02 996 turbo I am finally in a position to work on. I am planning on new turbos/exhaust/injectors, replace a leaking oil line, and the car needs a new clutch. I guess my question is, would it be easier to just go ahead and drop the entire driveline and get everything done with the engine out?? I have a hydraulic table and the exhaust/turbos/rear bumper/intercoolers etc are already off of the car. Thanks in advance
Old Aug 22, 2018 | 10:06 AM
Thinking's Avatar
Thinking is infamous around these parts
I don't know what's involved with pulling the engine/driveline, but it would make your job easier for sure. Not to mention all the "while your there" stuff you can do.
Old Aug 22, 2018 | 10:11 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Yes it will be much better to take it out. It is made to come out easily to be worked on. There are some things to know about the job but it isn't too difficult.
Old Aug 22, 2018 | 10:38 AM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
100% yes. It's fairly straight forward and will make all of the work you mentioned soooooo much easier! Just make sure you do it all while it's out and dont rush the reinstall.
Old Aug 22, 2018 | 11:28 AM
ktr6's Avatar
Thanks for the input, I think it will definitely make everything so much easier as well. Is there a good list of the "while you are in there" jobs to do?
Old Aug 22, 2018 | 11:50 AM
brnrdtns's Avatar
Pin or weld the coolant fittings, replace the coolant res, replace the idler pulley bearings, possibly change hoses, possibly change the vacuum lines and zip tie them, new DV valves, clean the FPR, new water pump. What else am I missing?
Old Aug 23, 2018 | 06:32 AM
Atrox's Avatar
Atrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud ofAtrox has much to be proud of
New engine mounts.
Old Aug 23, 2018 | 10:53 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
There is a good post in this section with a list of items to be considered while the engine is out. It's a must read! I did pretty much the whole list two years ago when I pulled my drivetrain.
Old Aug 23, 2018 | 03:50 PM
ktr6's Avatar
Thanks Gunther, I have started the disassembly! Headed to Harbor Freight for my table in the morning. Will look for the thread you mentioned to figure out what to do "while im in there". Will post progress as I move along! Appreciate everyones help and advice
Old Aug 23, 2018 | 05:37 PM
brnrdtns's Avatar
2 things I screwed up on removing my engine that are good to know:
There is a bolt on the top left intake manifold that holds the air intake in place. Remove that bolt because sometimes the intake pipes catch and it can crack the manifold.
Carefully remove the power steering line from the press in fitting thing on the ps res tank. If you scratch it the hose will not seal and you have to buy an overpriced new one.
Old Aug 24, 2018 | 05:59 PM
crash41301's Avatar
crash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to behold
Yes. Its made to come out easily. I can have the whole thing dropped within a few hours its so easy. With that much work you will hate yourself if you dont drop it out. Its not made for much of any service when in the car
Old Aug 27, 2018 | 06:08 PM
ktr6's Avatar
Getting closer, upper starter bolt wont come loose so working on that now. Otherwise I should have it all.......as far as I know. Will have my hydraulic table on Wednesday.
Old Aug 27, 2018 | 11:01 PM
Saadi996tt's Avatar
Saadi996tt is infamous around these parts
Planning on dropping my engine too, just got my mid rise scissor lift delivered and picking up the hydronic table this Sunday. Please post your progress...subscribed
Old Aug 28, 2018 | 09:12 AM
brnrdtns's Avatar
Be really careful if you are doing the jack stand method. I put a large wood block under the car just to be sure that if it falls it will not crush me. Lots of people die under cars on jack stands.
Old Aug 29, 2018 | 05:42 PM
ktr6's Avatar
Got my 1000 pound hydraulic table today from Harbor Freight for roughly $200. Have everything ready to drop the engine other than the upper starter bolt is frozen. Soaking with PB Blaster overnight, if that doesnt get it can take apart the passenger side rear suspension to make room for the drop.
