ceyanne gts front brakes on 996tt
I was looking into 6 piston brembo kits and they are all pretty expensive. I was thinking about a budget option, would the front breaks from a ceyanne gts fit on a 996tt with 19" wheels. I'm thinking about doing a stage 3 600hp build and need to upgrade the front breaks but I don't want to spend $3k-$5 on 6 pistons.
Those look like calipers from a new cayanne. Would it work with a ceyanne from around the same years as the 996? I don't know much about ceyannes btw so they might not have had 6 pistons back then.
Just get spacers between hub and OEM calipers F&R, 350mm discs from 997 turbo, decent pads and proper fluid and call it a day.
OR...
...you can follow my path...997 Cup front uprights, 991 GT3 calipers and 380mm discs F&R. Plus racing pads and fluid.
OR...
I found a brembo kit that has 355mm rotors but replacement brembo rotrs are pretty pricey. Could you use 350mm rotors?
acf
Jan 21, 2020 01:03 PM
TripleInboard
Oct 21, 2009 06:59 PM
