New Control arms Vs Polyurethane bushing?
Old Oct 11, 2018 | 03:03 PM
drebena's Avatar
drebena is infamous around these parts
After installing Ohlins Road and Track coilovers with GMG sway bars my suspension started making clunking noise. At first I thought it was the sway bar link and I replaced them. It reduced some of the noise. Now I noticed that the mounting plates are not the same. The passenger side allows the coilover to drift up an extra 1 inch. I assume that the rubber bushing is damaged because of the increase tightness in the setup.
I will replace the mounts with camber plates. While doing so should I replace the old upper and lower control arms or should I order Powerflex bushing and use the old components?
Any input would be appreciated.
Old Oct 12, 2018 | 08:31 AM
Slider's Avatar
Get the Elephant Racing camber plates - they allow for 3 times the adjustment of all others - necessary if you want to get close to OEM alignment specs with after-market suspension - better than OEM!
Old Oct 12, 2018 | 01:13 PM
drebena's Avatar
I wish I knew that before. I already ordered Vorshlag camber plates.
What do you think of the powerflex bushing?
Old Oct 12, 2018 | 02:20 PM
Slider's Avatar
I'm not familiar with the PowerFlex...
ciaka
Cayenne 955/957
Dec 5, 2019 03:17 AM
Steve Jarvis
Apr 6, 2016 08:30 AM
Little Gator
Jun 23, 2012 09:28 AM
VAGscum
Jun 14, 2011 12:05 PM
