Small leak top of transmission bell housing, need help identifying
Old Feb 7, 2019 | 09:17 AM
Lb4lb911's Avatar
Lb4lb911 is a name known to allLb4lb911 is a name known to allLb4lb911 is a name known to allLb4lb911 is a name known to allLb4lb911 is a name known to allLb4lb911 is a name known to all
Notice a slight sweating around a specific cable around the top of my driver side transmission bell housing. It is located further back. I’m hoping that fitting is just loose, but its extremely tight and cant even get a wrench in there to tighten. Can someone help Identify this hose/cable?
Old Feb 7, 2019 | 01:24 PM
brockster's Avatar
brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !brockster Is a GOD !
Possibly rear main seal
Old Feb 7, 2019 | 02:04 PM
Lb4lb911's Avatar
Do you have any solid info. to support that assumption? Not quite sure how that fitting/line it tied down to a rear main seal issue.....
Old Feb 7, 2019 | 03:34 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
That is likely a leak in the clutch setup. Rear main would not put oil on top.
Old Feb 7, 2019 | 03:45 PM
Lb4lb911's Avatar
I have changed my own clutch, rear main seal, accumulator, slave cylinder, trans mounts, turbos, oil lines, intercoolers, fuel pressure regular, engine mounts, turbo hoses, exhaust, coil overs, and much more. I was trying to help you narrow the possibilities.
It appears to be oil on the electrical connection to trans. The main culprit in that area is the rear main seal as far as oil goes. It could be Pentosin from the clutch but it's usually a larger leak as it's pressurized when activating it.
Ive also done all of the above on my car.... I just cant recall what this particular line is. Ive done entire oem gt2 slave conversion and cant remember where this line goes too. Another individual on rennlist mentioned
“This is a easy one.. Pentosin is leaking from the coupling or actual slave connection. It has a distinct smell. Same as your power steering fluid.”
I do believe its possible a clutch line. Just trying to figure out how I ll be able go sort it out seeing I cant even get some tools in there to tighten the line.
Old Feb 7, 2019 | 08:58 PM
'02996ttx50's Avatar
agree. not rms. i had a porsche factory tech remove and re-install the trans once after a leak was discovered. it was top of the housing, but also a decade ago. cannot recall the source. but no way thats the rms.
Old Feb 12, 2019 | 07:43 AM
slave or accumulator or clutch line
#TeamAIM
Old Mar 5, 2019 | 10:51 PM
kamkaz's Avatar
kamkaz is infamous around these partskamkaz is infamous around these parts
+1 for this advise.
That's what happened to me. Possible to change it without an engine drop... I did.
JustinCase
Jan 3, 2016 03:39 PM
Ringlord
Jul 2, 2015 09:04 AM
fullmetaljacket
Oct 22, 2012 08:46 AM
w00zie
Sep 2, 2010 07:49 AM
tsweat
Sep 26, 2004 02:51 PM
