DE tire check in
Old Mar 16, 2019 | 10:12 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
DE tire check in
Hey folks I’m back in a 996tt (AWD) with decent track capability and bought some new APEX wheels 9”/12” and need tires. I’ve ran NTs on previous cars and enjoyed the performance/value and will go that direction again I suspect as I need to move quickly. the car is ~GT2 height and will be aligned well. I know I need to watch front rear ration <3%.
235/315 is an easy option
245/305 was what is used on my GT3. Per Discounttire they are 26” diameter. Anyone using this on an AWD car? How is fit/rub?
NTs are tried and true but really enjoyed my Cup2s on the 350R and 7.2TT as well.
Thoughts please.
Old Mar 16, 2019 | 12:41 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
I bought and will run 245/315 on nitto nt01s. It is a common and popular size. I probably have the same rims as you. apex sm-10, front 18 x 9 et 46, rear 18 x 12 et 45. I bought the rear gt fender liner support (~$25) to allow for a bit more space in the back for the 12'' rim. In the front you'll need to mod the radiator bracket, and heat up and bend the front fender liner. None of it is hard work, Freddy even does the radiator brackets without taking them off the car. Good luck. For more info, you can look up pwdrhound's posts on all of this. He has answers for everything...
Old Mar 17, 2019 | 07:47 AM
Etchhead's Avatar
Thanks much and yes Powderhound is the master at all of this- his posts/build is amazing!
Yes we have the same wheels- look forward to getting them shod and mounted... and the new car for that matter!
Old Mar 18, 2019 | 06:43 AM
trillypop's Avatar
trillypop is infamous around these parts
Thoughts please.
I run 245/645 and 305/645 track rubber on twists. No issues with rubbing or AWD. Works really well for me now. I'd eventually like to go RWD and get new track wheels so I can run a 265/315 setup, but that's for another day.
Old Mar 29, 2019 | 09:12 PM
chuoiit35's Avatar
chuoiit35 is infamous around these parts
Lagihitech
, thanks you
HRE_Wheels
Audi
May 31, 2014 05:19 PM
SHANKENFELTER
Aug 15, 2004 07:53 AM
