Best low dust brakes currently?
Old Apr 21, 2020 | 03:33 PM
  #31
Slider's Avatar
I went back and checked the weight thing - here is what the weights look like. I think these are in the front and the little round ones in the rear...
Old Apr 21, 2020 | 03:54 PM
  #32
'02996ttx50's Avatar
thx slider, i am stymied as i dont even recognize those! but if missing? man, that would suck but explain. thx, will look into it next time i do pads. fronts are "soon".
Old Apr 21, 2020 | 04:08 PM
  #33
Slider's Avatar
Eh... it only takes about 10 minutes per side to put them in - not a biggy...
Old Apr 21, 2020 | 06:53 PM
  #34
yeah, how long could it take? lol i'm just wondering why i had no idea what they are/were and why i may be missing mine!
have you known of installing pads and leaving them off, inadvertently or whatever? i swear. never seen them before.
Old Apr 21, 2020 | 10:33 PM
  #35
Slider's Avatar
It would be hard to leave them off inadvertently because they would be sitting on the floor after the pad change and you would be wondering where they went - although - you may have thought they were part of the pad if they were firmly attached (and they usually are) and tossed them in the garbage stuck to the old pad. If you didn't notice the difference, I guess you could.
I have only replace the weights once. I think I've changed pads 3 times in the last 10 years.
Old Apr 21, 2020 | 10:42 PM
  #36
i appreciate the advice and the mystery. how many brake pads have i gone thru in a decade plus also, and never even seen or known of these? and yet.
this is the first time ever i have had the ( albeit ) cheap a** textars squealing on this porka. i will look more closely when i next remove the bits and report accordingly. thanks again.
Old Apr 26, 2020 | 10:04 AM
  #37
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
You may have never seen them because they remained stuck in your calipers. When in the calipers the brake pad side will simply look like two flat round discs in the back and just a flat metal plate in the front. I've changed pads regularly between track and street but have never changed these shims. I have had no squeal with street pads.
Old Apr 26, 2020 | 01:55 PM
  #38
that makes sense, thanks. the irony is that since i mentioned the squeal i've had over the last 2k miles since i swapped pads. it has ( for now ) seemingly stopped and it's worse when it's "hot" outside, which it is. really odd. like i reverse jinxed them by mentioning it lol.
maybe it had to do with material depth, who knows - hope they stay quiet.
ca86108
Mar 21, 2019 06:40 PM
saint01
Jun 25, 2018 07:17 AM
metzkaro
Jul 19, 2012 11:59 AM
donshin
Jun 5, 2009 01:53 AM
