The bug bit me... Again
Old Oct 4, 2019 | 02:15 PM
RickyN F355's Avatar
RickyN F355 is infamous around these partsRickyN F355 is infamous around these parts
curious what you end up with...here is my build from about 8 years ago done by EPL. been wondering if one were to do a build today wld it look much different?
TiAL Alpha3076 Turbo Kit
996tt - Turbo Install Kit
8.5 Labor - 8.5 Hours - Turbo and water line
6 Labor - 6 Hours - Fuel injector install
Clutchmasters 20-934-HDTZ Stage 3 Clutch
12 Labor - Clutch and flywheel installation
OEM Dual Mass Flywheel - 996
9 Flywheel Bolt -
Clutch Lever Shaft Cap -
Clutch Lever Bearing -
Europipe 2 loud
2 Clutch Lever Shaft Seal -
2 Release Arm Bushing -
USP 996TT High-Flow Inlet Pipes
3 Labor - 3 Hours - Inlet pipe installation during clutch install
AWE Tuning 996tt Intercoolers (Silicone Hose kit included)
1 Labor - 1 Hour - Trim OE shrouds to fit AWE I/Cs
2 I/C Hose O-Ring - 996 1
6 Spark Plug - Bosch FR6-LDC
6 Ignition Coil
Serp Belt -
Fuel Filter
Nick@Autogeek
Detailing
May 17, 2011 12:43 PM
BCS996TT
Jul 28, 2003 08:54 AM
