Recommendations on Bug & Tar remover?
Old Jul 27, 2003 | 01:10 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
For you detailing experts out there...what's the best paint friendly bug and tar remover?
Old Jul 27, 2003 | 03:32 PM
cjv's Avatar
cjv
Moderator
3M general adhesive remover. It costs less through Griot's.
www.griotsgarage.com
Old Jul 27, 2003 | 03:59 PM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
which is it bugs or tar that you trying to remove?
tar, I don;'t have a recommendation, bugs however, the very best IMO is a towel soaked in luke warm water and let set on the bugs for 10 - 15 minutes.
Old Jul 27, 2003 | 07:56 PM
Andrew708
Guest
Posts: n/a
hey bcs..i detail cars all day long,and the way to remove bugs,and i mean the right way is to clay the car,then polish and wax the area!!! pm me for further help
Old Jul 27, 2003 | 08:56 PM
msindi's Avatar
Zymol HD cleanse works too but then you have to re-wax!!
Old Jul 27, 2003 | 09:03 PM
cjv's Avatar
cjv
Moderator
msindi,
I believe anything but soaking in warm water would require re waxing that area.
Old Jul 27, 2003 | 09:06 PM
Aron's Avatar
Aron is infamous around these parts
Good wax job. Got some tar behind the passenger side wheels, came off with the wash mit with only a little pressure.
Old Jul 27, 2003 | 10:18 PM
NJPete_2003996T's Avatar
NJPete_2003996T is infamous around these parts
Porsche makes a good Bug remover, which i would probablly try first. WD40 is a bit harsh but usually works as well. For stubborn bugs, and sap use a clay bar.
Old Jul 27, 2003 | 10:58 PM
dpblessing's Avatar
senior member
I don't know why everyone always wants to use some chemical and scrub the **** out of the spot to get bugs off when all it takes is a luke warm (hell it can even be cold) water soaked towel layed over the area and let the bugs rehydrate. They slide right off, no scrubbing, no rubbing, no swirl marks, no nuthin (if you let them soak long enough) - really...
Having said that.. I also just tried Detailer708's trick with the clay, and I was pleasantly surprised that it worked extremely fast and completely.
So, if I am washing the entire car, I will still use the soaked towel routine. If just removing a few bugs between washes, clay it is!
Good tip detailer!
Old Jul 28, 2003 | 08:45 AM
Andrew708
Guest
Posts: n/a
Hey Doug...no problem..i am around this all the time...most of the exotic cars that i see have tons of bugs on them from being so low..one thing..if you clay something,them after you wash it you need to atleast wax that part!
Old Jul 28, 2003 | 08:54 AM
dpblessing's Avatar
senior member
Thanks again Andrew.
Bodessem
Sep 10, 2015 02:50 PM
AM v12v
Sep 7, 2015 02:17 PM
Weebs
Sep 7, 2015 11:42 AM
Wildcat1212
Sep 7, 2015 11:31 AM
