Coolant Pipes experience/replacement?
Old Aug 14, 2019 | 04:34 PM
wab_jr's Avatar
5 Year Member
wab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud ofwab_jr has much to be proud of
Pulling the engine to weld the coolant pipes. Anybody have experience with the Torque Solution pipes? Or is there an upgraded Porsche solution?
Billy
Old Aug 14, 2019 | 08:25 PM
rennteche55's Avatar
rennteche55 is infamous around these parts
Billy
I haven’t personally done it, but I will be doing it this winter with the BBI kit. You can buy it and have a local welder do it. Or send it to them and have them weld it/ pressure test it.
Old Aug 14, 2019 | 08:46 PM
wab_jr's Avatar
5 Year Member
Ive been looking at the BBI & Torque Solutions product.
Its hard to glean anything significantly different between these two producers. Good news for me is I’m close to some aluminum machine shops that are NASA subs.
Old Aug 15, 2019 | 09:51 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I have the TS and they are good. You need to re use the curved pipe though.
Old Aug 15, 2019 | 09:55 AM
wab_jr's Avatar
5 Year Member
Thanks for this heads-up.
im sure this would have confounded me,
Old Aug 15, 2019 | 02:44 PM
Pry really not any difference between the 2 since they’re just little pieces of pipe. I just liked the fact you can send your pieces into BBi for welding. Looks like you don’t have the issue of looking for a good welding shop though.
Old Aug 15, 2019 | 02:50 PM
wab_jr's Avatar
5 Year Member
I am fortunate to have an out of this world welding shop resource...
Old Aug 16, 2019 | 08:00 AM
brnrdtns's Avatar
Indeed, I was confounded. I made them send me an extra pipe for free and I added a piece of hose to the line. I never realized until later that I was supposed to re use the curved one.
Old Aug 16, 2019 | 11:19 AM
g-50cab's Avatar
g-50cab is infamous around these parts
Billy
Porsche has stuck their head in the sand on this one - I guess as soon as the cars go out of warranty - some well out of warranty then it's not their problem. Unreasonable on their part to assume a glued in joint for an aluminum fitting that goes through heat cycles would be an effective engineering solution.
ciaka
Cayenne 955/957
Mar 22, 2017 06:02 PM
onefastman1
Apr 5, 2013 09:12 PM
aalleoxn
Cayenne 955/957
Jan 18, 2013 05:24 PM
jrblackbox
Cayenne 955/957
11
Jun 5, 2012 12:21 PM
florez773
Cayenne 955/957
10
Jun 20, 2011 07:57 PM
