Shocks
Old Feb 27, 2006 | 07:37 PM
devious996TT's Avatar
devious996TT is infamous around these parts
Shocks
Which shock would you recommend?
1) PSS9
2) Moton
3) KW Variant 3
4) Ohlins
5) other (name)
Old Feb 27, 2006 | 08:00 PM
wross996TT's Avatar
For what exactly...track, street, DE, DD...blah, blah, blah?
I have FVD PSS9s for street use only and I love them.
Old Feb 27, 2006 | 08:03 PM
for street... I use to own a KW variant 2 on a BMW... but for this new porsche.. ppl seem to use PSS9... so i'm not sure which one i should go for... price wise is approximately the same... and moton is a tad too extreme for me... i don't need all the settings because i won't touch it once it's set...
Old Feb 27, 2006 | 08:29 PM
tom kerr's Avatar
PSS9's but for the street even these may be over kill. Motons are my choice for the track.
If you are changing just for ride height you could just have the springs changed and the car would be 1-2 inches lower and would be best "bang for the buck"
My car came to me at the "proper" ie lowered ride height by the previous owner changed the springs to H&R's and just that set up handled pretty well at DE's also
Old Feb 27, 2006 | 08:42 PM
AlanS's Avatar
AlanS is infamous around these parts
Just got the PSS9s installed
I just got the PSS9's installed and I really like them. I have them set on 5 (Front)/4 (Rear). The ride is a little firmer, but not harsh at all. I only lowered the car about 3/4". One item I noticed is the car does wallow a bit in corners before it settles down. It's more noticable in some corners than others. It's the progressive spring rate that contributes to this feeling. I've ordered the H&R sway bars and increase the roll stiffness and address this issue. If you go with the PSS9's I suggest installing the H&R sway bars at the same time. AWE Tuning may still have the PSS9s on special for $2100.
Old Feb 27, 2006 | 09:19 PM
ok... i think i'm going to go for the PSS9!
Old Feb 27, 2006 | 09:22 PM
Ruiner's Avatar
1) PSS9
2) Moton
3) KW Variant 3
4) Ohlins
5) other (name)
Just shocks or shocks/spring (coilover) combo?
Old Feb 27, 2006 | 09:34 PM
supercup's Avatar
supercup is infamous around these parts
Moton's for street or track!
Old Feb 27, 2006 | 09:56 PM
Zippy's Avatar
Look at GT3 swaybars also. They are pretty inexpensive and will give you additional options that PSS9's alone will not.
Old Feb 27, 2006 | 09:57 PM
coilover system...
Old Feb 27, 2006 | 10:16 PM
Ruiner's Avatar
coilover system...
May I suggest JICs over PSS9s? They have a few advantages over the PSS9s in terms of lowering/bumpstops/ride selection/spring rates/etc.
Old Feb 27, 2006 | 10:35 PM
what system are you running Ruiner?.. btw, why hasn't anyone said anything about the KW Variant 3 system?... is it not good?.. or is it just not popular?
Old Feb 27, 2006 | 10:41 PM
Ruiner's Avatar
I'm running the JIC system with spring weight 7kg front/10kg rear. They offer 3 systems (you can look on their page).
http://www.jic-magic.com/productscross.htm
I haven't heard much about the KW systems with the 996TTs in all honesty. I am not sure how adjustable they are, if at all.
Old Feb 27, 2006 | 11:31 PM
03-turbo911's Avatar
Senior Member
Buddy G's running KW's so pm him if you want an impression. I know that the vario 3 is one of the best coilovers in the market. Manthay Racing use a specially valved version that's made for them by KW.
For the street, Motons, Ohlins and the like are certainly overkill. There's a choice of PSS9's, Bilstein factory, FVD specs and RUF spec. Of those, I've been in the RUF spec and it comes complete with a rear sway bar. The ride is much better than stock and the car feels transformed.
Porsche also offer the X73 coilovers and some say that these should have come standard on the turbo. They are non adjustable but are factory quality.
Old Feb 28, 2006 | 12:12 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
i picked up a slightly used set of JIC Cross coilovers for $1200 on 6speed. I'm having them installed in the next couple weeks with a few other mod's. I hear good things!!!
