I might've messed up with the naming. It's the part pictured below. Should I replace them with GT3 ones or are there better aftermarket adjustable alternatives?
Car is '02 996tt on PSS9. I'm also having GT3 lower control arms installed front and rear.
They are called tension arms or sometimes referred to as thrust arms. Stock GT3 are fine or you can install the Porsche Motorsport RSR versions which have anti squat geometry (shown at bottom of pic below).
" target="_blank">
" target="_blank">
[/ame]
