What’s everyone using for 1000whp e85 fuel pump?
Old Jan 18, 2022 | 09:30 AM
nitrorocket's Avatar
nitrorocket is infamous around these parts
Thinking of changing out my fuel pump, car makes 1000 wheel horsepower, looking for an intank set up, currently have a -8 and a -10 feed and return running to the original sending unit.
Just curious what’s out there right now for good mostly plug-in-play pumps?
Old Apr 6, 2022 | 01:42 AM
Bugeater's Avatar
Bugeater is infamous around these parts
I'm using protomotive's in-tank setup. Its a dual pump setup..
Just converted over. I'm at the same power level. Was tired of leaning out on gas and and smallish injectors.
Old May 14, 2022 | 01:02 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
I needed 3 pumps (also from proto) to go over 1k whp, what pumps are you using? thx
Old May 25, 2022 | 08:53 PM
pwdrhound's Avatar
We are using the TiAutomotive Brushless pump with the PWM controller which continually varies pump output from 40% to 100% output based on boost and engine load. This is an extremely efficient pump operating at a max current draw of about 11 amps. This is the OEM pump used in the Bugatti Veyron. We have this set up as a returnless fuel system with a single supply line going to the engine with no return similar to 997 and later generation cars. This completely eliminates any reheating of the fuel due to a lack of a return line from the engine back to the fuel tank.
https://aftermarket.tiautomotive.com...less-fuel-kit/
Old May 26, 2022 | 09:16 PM
Ms4cd's Avatar
That looks like a nice solution, is that what you use in your race car?
Old May 26, 2022 | 09:38 PM
pwdrhound's Avatar
Correct. It really simplifies everything because all the fuel components including the fuel pressure regulator, fuel filter, and fuel damper are in the front trunk near the fuel tank. The single fuel line that goes to the rear of the car simply splits at the engine with Y into two fuel lines each one feeding the respective fuel rail.
Old Jun 6, 2022 | 04:40 PM
Rvca3112's Avatar
Rvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant futureRvca3112 has a brilliant future
Is it true for cars with fuel pump upgrades that you shouldn’t run them before half tank?
Jeanmarcboilard
Oct 10, 2016 08:45 AM
Yazz911TT
Nov 24, 2012 10:34 AM
marsfire
Aug 8, 2011 05:22 PM
FAST FWD
Aug 20, 2010 11:31 AM
SkierMan
911
Sep 12, 2006 07:41 PM
