Whistling sound from rear
Old Mar 31, 2025 | 06:08 AM
maxrod's Avatar
maxrod is infamous around these partsmaxrod is infamous around these parts
G'day all.
My beast, X50 TipS Cab makes a whistling sound occasionally from the rear at between 2,500 to 3,000 RPM while accelerating, then it goes away. Feels that is coming from the drivers side. I had been reading that it would be the Aux/secondary Air Pump, and hope is not the turbo. Any thoughts on the matter?
Old Apr 1, 2025 | 04:23 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
Most certainly the airpump
Old Apr 1, 2025 | 05:08 PM
maxrod's Avatar
Thank you. That is what I was thinking. I am more experienced with naturally aspirated engines and not turbos. I am however, a Quick Study :-)
Old May 3, 2025 | 01:45 PM
speedorange's Avatar
speedorange is infamous around these partsspeedorange is infamous around these parts
I had a similar hiss on my 996 Turbo, exactly in this rev range. In my case, it was indeed the secondary air pump – a rather high-pitched and brief noise. The turbo instead makes a more constant whistle or a leaky noise. If the performances are good and no error codes, I would also bet on the pump. To watch, but nothing alarming in my opinion
Old May 3, 2025 | 04:38 PM
maxrod's Avatar
Thanks, I purchased one that odly enough is made in China. FCP Euro has two units, one OEM and one also made in China. So lets see how the Chinese goes. I also purchased a new relay as it is stated somewhere that it should also be changed. Once I do the exchange, I will take apart the old one and refurbished.
hollywood996tts
Oct 3, 2016 07:53 AM
johnmiller
911
Aug 3, 2012 09:11 AM
spinny02
Cayenne 955/957
Nov 4, 2011 11:41 AM
mjb2503
Cayenne 955/957
Oct 29, 2011 04:29 PM
911stripper
Jul 5, 2011 01:17 PM
