Difference between US and ROW Turbo rear bumper...
Old Apr 3, 2006 | 08:05 PM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Anyone know the difference between the US and ROW Turbo rear bumper? Is it the same bumper without the bumperettes? Or is it actually a different bumper?
Old Apr 4, 2006 | 12:46 AM
03-turbo911's Avatar
Senior Member
It's the same design bumper but without the bumperettes. So it's a different part number if that's what you meant.
Up to the 996, we used to get US type bumpers. Not anymore with the 997. This is a picture of my bumper which had the bumperettes removed and the holes filled in.
Old Apr 4, 2006 | 01:25 AM
newport996's Avatar
i guess my question is, would a US bumper with the bumperettes removed and holes filled look EXACTLY the same as the ROW bumper? The space for the license plate would be the same width, or would the US look funny because of such a wide space?
Old Apr 4, 2006 | 02:51 AM
Senior Member
I guess I answered your first quistion. My car came with the bumperettes and I had those removed. We have a choice of plate sizes here so, in your case, it's all a matter of personal choice. This is the only picture that I have of a small, US type, license plate with a Euro bumper. Hope it helps.
Old Apr 4, 2006 | 05:53 AM
benguss's Avatar
benguss is infamous around these parts
I have removed my black bumpers from my car. But you have to remove the rear bumper cover to access the aluminum holders that are attached to the bumper, these are riveted on and can be tapped out fairly easy. You are left with two large square holes with one hole with a half circle for the european bumper tow hook. American spec have tow hook , center, right under the license plate. euro spec is on the upper right. You can get creative to mask these two holes. if you install euro spec rear bumper cover you will not have a tow hook unless you drill hole under the plate. or redrill hole where euro has them.
Old Apr 4, 2006 | 10:46 AM
cjv's Avatar
cjv
Moderator
Very good description.
The bumpers are the same. Porsche cuts the holes out for the US version. I removed mine as benguss described above and here is my solution. I used the holes for my nitrous vents.
Old Apr 4, 2006 | 11:28 AM
newport996's Avatar
Great info...THANKS!
Old Apr 4, 2006 | 12:23 PM
benguss's Avatar
great pix cjv!! On mine I put a aluminum screen on the inside with aerospace fasteners that show thru the bumper to give it a "raw" look. I also cut the square holes bigger to get rid of the euro tow hole. I really like your set up. While I was at it , I cut a slit to install a race tow ring just above the euro hole. It looks ok but I wish I didn't install the red tow hook ....I guess a little prepuberty got hold of me!!
COBB Tuning
Jan 1, 2025 09:02 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
adnanm3
Oct 25, 2016 08:38 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
