Help!!! Boost Problem
Old Apr 5, 2006 | 09:39 AM
Buck 80's Avatar
Buck 80 is infamous around these parts
Hey guys. I am having a problem getting full boost on my 2001 996TT. I know, Limp Mode, right? I'm not so sure. The car has an EVO stage IV with headers, 100 cell cats, straight pipes, and billet diverter vales. It will intermittently max out at .4 to .5 bars of boost, then spike to 1.1 bar without any consistent pattern. I initially would disconnect the battery to reset the ECU for about an hour which led me to believe it was in Limp Mode, but now it comes and goes without resetting ECU. Help!!! Could it be a leak in the system, i.e. diverter valve hose, turbo boost controller problem, or is running straight pipes with cats causing it?
I appreciate any suggestions for I am taking the car to VIR on Sat-Sun for a track weekend and would like to have this sorted. Don't want to be passed and embarrassed by the Vipers and Zo6's. Lol
Thanks,
Bill
Old Apr 5, 2006 | 09:48 AM
TonyNJ's Avatar
TonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of light
Bill, how are you my man? It sounds like a boost leak to me, I had a similar issue.
Old Apr 5, 2006 | 10:15 AM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Although I'm not any expert, sounds like a leak...hoses? I'd get it in for a check. good luck..you should be hitting like 1.2 at WOT with a stage 4 setup
Old Apr 5, 2006 | 10:20 AM
Buck 80's Avatar
Thanks TonyNJ and Willcoxmd for your help!
Old Apr 5, 2006 | 10:29 AM
TonyNJ's Avatar
No problem Bill, good luck with your fix.
Old Apr 5, 2006 | 10:54 AM
tom kerr's Avatar
Do you have the turbo silicone boost hose upgrade?? May need it.
Old Apr 5, 2006 | 10:59 AM
sharkster's Avatar
Sounds like one of your boost hoses is partially out... With a leak like that your car will run just like it is Take your bumper off (after you've checked the ones to the y-pipes) and see if the hoses going to the intercoolers from the y-pipe are slightly out.
Old Apr 5, 2006 | 06:42 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Boost leak may lead to engine running too rich so don't drive the car for too long.
Old Apr 5, 2006 | 07:16 PM
sharkster's Avatar
Thanks,
Bill
James said you called.. did you work it ok?
Old Apr 6, 2006 | 10:58 PM
Buck 80's Avatar
Thanks Sharky and everyone for their replies. I tried tightning all the boost hoses and it seems to have fixed the problem. I will be at the race track all weekend so that should shake out any gremlins for sure.
Gracious!
Old Apr 7, 2006 | 03:40 AM
sharkster's Avatar
Gracious!
Cool and no worries... James is better at explaining that stuff than I am
adnanm3
Oct 25, 2016 08:38 AM
Evan5469
Oct 29, 2015 06:39 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
nal991
Sep 11, 2015 09:05 AM
rsdub
Sep 10, 2015 03:30 PM
