Question on Air Diffuser for Techart Bumper
Old Apr 7, 2006 | 09:03 AM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Just curious, when you install a Techart bumper that has the air diffuser (slats on top part of bumper) where does the water run in the rain, etc.? Does it simply go over the radiator? I have never seen one installed so I'm curious.
I think the GT2 bumper has a duct of some sort that drain below the car.
Thanks,
Adam
Old Apr 7, 2006 | 09:29 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I just installed the Techart bumper, and had no ducts to drain. Basically it just runs down on top of the aluminum bumper support and radiator. Looks like nothing to rust or be damaged by rain under there. Guess it is fine since with a stock bumper rain just flies into the front radiator housing and it still will get wet back there. Here is a link to when I did mine... https://www.6speedonline.com/forums/...ad.php?t=44095
Also if you do the install, make sure you spray paint the aluminum bumper support black. I skipped that step, and when I look into the slats, you can see the aluminum...not really a big deal actually...but wish I did spray paint it now.
Old Apr 7, 2006 | 10:13 AM
alevine's Avatar
M3CAB:
Awesome. Thanks for the info. I never know how this worked. Good tip on painting the aluminum support black. Thanks.
Adam
Old Apr 7, 2006 | 10:38 AM
M3CAB's Avatar
Are you planning on doing the install yourself? If so PM me, and I can give you some tips.
Old Apr 7, 2006 | 02:53 PM
its a B@tch... I did it as well...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 7, 2006 | 04:36 PM
wross996TT's Avatar
My advice is to have the bumper fit first, then painted, then installed. I had it done by my paint and body guy and it came out nice...but there were some tweeks needed!
Jul 29, 2019 11:13 AM
adnanm3
Oct 25, 2016 08:38 AM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
