Any tips on installing the EVO intake?
Old May 11, 2006 | 01:36 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Hey guys, just picked up an EVO intake for my car. Any tips (other than following the instructions) in terms of the install process? Diconnect the battery? TIA!
Old May 11, 2006 | 01:45 PM
oak's Avatar
oak
yes, keep a back up MAF in your glove box... if you have one.
Old May 11, 2006 | 01:46 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
LMFAO
Old May 11, 2006 | 02:43 PM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I thought the MAF issues have been resolved with the latest update to the design of the system? I just ordered this intake so i hope I'll have no issues.
Old May 11, 2006 | 03:01 PM
Bill in Atlanta's Avatar
Bill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud of
Tips ?? Don't install it
Old May 11, 2006 | 03:13 PM
john revis's Avatar
john revis is infamous around these parts
It took me about 30 minutes to install it. No problems except the filter was a little tight. Check to make sure it has a drain hole. It's supposed to, but mine didn't.
Old May 11, 2006 | 03:36 PM
Westwood's Avatar
Westwood is infamous around these parts
I installed mine this winter and have not had any issues at all.
Roger
Old May 11, 2006 | 04:04 PM
Fanman's Avatar
Fanman is infamous around these parts
Somebody in the past had crushed one of their hoses when they did the install, and mde the car freak out, just be careful, and you should be good to go. Also, in the past (not sure it is as much a problem now), people took the filter out the night or two before the install & put it over newspaper to soak up the excess oil.
Old May 11, 2006 | 05:41 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Martin if you have any problem call me, you've got my number
Jags
Old May 11, 2006 | 05:59 PM
Nate@EVO's Avatar
Nate@EVO is infamous around these parts
I am sure that you have already seen them online, but we have detailed install instructions for that kit. If you follow those, you will have no problems. The kit is very easy to install and you should have no problems. If you do, please give me a call, I wrote the instructions so I will be able to help you out. Thanks...
Nate
Old May 11, 2006 | 06:31 PM
Where should the drain hole be? Under the filter or on the other side?
Old May 11, 2006 | 06:37 PM
Nate@EVO's Avatar
I believe that they are putting the water drain holes below where the filter resides. Where are the holes on your kit?
Old May 11, 2006 | 06:46 PM
I will check when I get home....is it a good idea to disconnect the battery to allow the ECU to reset?
Old May 11, 2006 | 06:52 PM
Nate@EVO's Avatar
You shouldn't have to do that, I know that some customers always disconnect their battery to clear adaptations, but I really don't know if it is going to make a difference.
John@SpeedTech
Aug 23, 2015 12:07 AM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
