Ruf PSS-9 shock adjustment
Old Dec 25, 2003 | 02:42 PM
john stephanus's Avatar
john stephanus is infamous around these parts
Hey Guys,
Wondering how one adjusts the front shock settings on the Ruf PSS-9 setup. I was told that the adjustors are on the sides of the struts...but I don't see them. Are the adjustors under the blue rubber cap on the bottom of the strut?
Thanks,
Old Dec 25, 2003 | 03:10 PM
sporters78's Avatar
sporters78 is infamous around these parts
that where they are, what setting are you useing. i was at #4 moved the setting to #3 allround.
Steve
Old Dec 25, 2003 | 05:13 PM
msindi's Avatar
You got it - under the blue cap...Although I have never adjusted these myself, I hear that knowing which number is what position can be tricky...
Old Dec 25, 2003 | 05:20 PM
sporters78's Avatar
not that tricky, there is a line on the bottom of the adjuster that you line up, of course its in a hard place to see but if you look on the outside toward [wheel side] the bottom of the adjuster you will find it.
Old Dec 25, 2003 | 06:50 PM
luting_chen's Avatar
luting_chen is infamous around these parts
what level came as stock?
i have my ruf installed too... but not sure what my setting is... (i believe is the ruf recommened level)
i wanna try different setting... can you guys recommend one?
Chris Y?
Old Dec 25, 2003 | 06:54 PM
msindi's Avatar
I have 3 all around but might try 3 in the rear and 4 in the front per recommendation from a fellow board member WhiteTT
Old Dec 25, 2003 | 07:45 PM
Chris Y.'s Avatar
Chris Y. is infamous around these parts
Hey Kevin...
I've tried almost all the settings and all kinds of different combinations...I settled at 4 front and 3 rear for a nice neutral feel. Asgar recommend 4 all around, but I like 4/3. But try it out...and see...3/3 or 4/3 seems to feel the best for me and everyday driving.
Old Dec 25, 2003 | 10:43 PM
Am I correct that a higher number equals stiffer?
Old Dec 26, 2003 | 04:49 AM
msindi's Avatar
Yup...9 is the softest, 1 the firmest
Old Dec 26, 2003 | 09:31 AM
Okay...I am confused...are higher numbers stiffer or softer?
Old Dec 26, 2003 | 10:21 AM
KPV's Avatar
KPV
The lower the number the more damping. Assuming you do not have any other suspension modifications, I would recommend the rears always be set at a lower number than the fronts. This will tend to counteract the inherent understeer characteristics of the car.
I currently have mine set at 3 front and 2 rear. I plan to experiemnt with higher settings soon.
Old Dec 26, 2003 | 04:08 PM
Thanks much guys...set them at #4 front and #3 rear.
Will follow up with how that feels.
Old Dec 26, 2003 | 06:14 PM
cjv's Avatar
cjv
Moderator
John,
Did you send your car to Weissach Performance?
Old Dec 26, 2003 | 06:23 PM
KPV's Avatar
KPV
Hey John,
Side note...............
Take a look at Sean's RUF RTurbo car's performance at the recent AWE Tuning Dyno Day. The 550 hp you quote is a bit off!!! It is more like 600 hp!!!
Old Dec 27, 2003 | 02:11 PM
CJV...yes I did...nice people.
KPV...yes, thanks, I saw the dyno of Sean's. I imagine that it is the same as mine. I will be dynoing mine on a Mustang in the next week or two and will post the results.
Thanks,
