K24's
Old Aug 9, 2006 | 07:08 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
K24's
Just Rec'd My Brand New K24's! What Now?
Old Aug 9, 2006 | 07:22 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
I would say map the ECU
Old Aug 9, 2006 | 07:37 PM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
ECU mapping, DVs, exhaust, headers, intake, wastegate .......... K24s were just a start!
Old Aug 9, 2006 | 07:51 PM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Hey Paulie, where did you get the 24`s and how much, thanks Mike
Acropora's Avatar
Acropora has a spectacular aura aboutAcropora has a spectacular aura about
Speak w/ Kevin www.ultimatemotorwerks.com and have a nice compressor wheel installed in them. Then mod the ecu and say goodbye to the tread on your tires...
Old Aug 9, 2006 | 07:55 PM
Kevin has break product... Evoms/IA is reputable... FVD is good as well.
I had 3 set ups... including k24s... and k24 hybrids...
good luck,
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 9, 2006 | 08:58 PM
Mike, I Got Them Off E-bay. I Paid 2675.00 They Are Brand New In The Boxes ,straight From Borg Warner.
Old Aug 9, 2006 | 09:10 PM
Markski, I Have Giac I.o Bar Tunning ,fabspeed Exst,dv's,evo Intake. Will I Still Need To Re-map The Ecu? Also What About W/g's. Should The Stock W/g's Be Ok Or Go For The Evos Upgrade?
Old Aug 9, 2006 | 09:14 PM
since u gave giac u can upgrade to the stage 4 program I think for less then retail...
At one point I had stage 4 ecu from fvd and a k24 running... meant for stage 3 program... and it was fine...
if u keep the same ecu I would get the upgraded wgs and see what happens... if u go with the upgraded Wgs then I would change the program for sure...
markski
9.66
click to view
Old Aug 9, 2006 | 09:21 PM
Markski,i Have Heard The Best Header Set Up Are The Stock Ones But To Have Them Worked On. Does Kevin Do This?
Old Aug 9, 2006 | 09:30 PM
kinda true if ur under 600HP... I had them as well.
9.66
click to view
Perrew
993 Turbo
Dec 9, 2016 08:35 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
sharkster
Jan 21, 2006 10:41 AM
