Help with CEL code....
Old Oct 17, 2006 | 04:48 PM
RESQ911's Avatar
RESQ911 is a jewel in the roughRESQ911 is a jewel in the roughRESQ911 is a jewel in the rough
I got the infamous CEL after starting the car 3 days ago. Today I took it to my local shop and he said it read P123, but he also said that it stated "secondary air pump system". He said that he believes it could be something to do with the smog system. He also said that he could not find P123 in the computer and that he found P418 as the code that dealt with the secondary air pump system. The car drives fine and he reset the CEL. It's a '01 TT. Any help will be appreciated.
I'm pending CA smog test, so I need to get this resolved. Thanks for any input.
Old Oct 17, 2006 | 10:59 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
sounds like faulty diverter valves. Try replacing them and the f hose. Good luck.
-Suman
Old Oct 17, 2006 | 11:52 PM
PorschePhd's Avatar
Check the vacuum port on the top of the BOVs. This is the code you get when the line is venting to the atmosphere. The line rubs through causing it to leak.
Old Oct 17, 2006 | 11:57 PM
RESQ911's Avatar
Suman, diverter valves have been upgraded. Stephen thanks for the info.
Old Oct 18, 2006 | 12:16 AM
PorschePhd's Avatar
My pleasure.
Old Oct 18, 2006 | 12:53 AM
sharkster's Avatar
RESQ911.. if you're able to make the trek down to Fremont, I've got a PST2 and can give you more info on what it is/might be if you like... I can also make sure it's in the "readyness" state (the screen has to show happy faces) for SMOG after that. If you reset it the CEL you'll still need to wait until the car is in "ready" status for smog.
Old Oct 18, 2006 | 01:21 AM
PorschePhd's Avatar
If you clear the code and it comes on in the first 20 seconds of cold start up then it is the BOV line What the hell is readiness status We don't have that here.
Old Oct 18, 2006 | 12:07 PM
sharkster's Avatar
Don't you start That readiness state thing is such a polava really... Although I see their point. If it wasn't for that then I guess everyone with an OBDII scanner could clear their codes like 5 seconds before the test....
Old Oct 18, 2006 | 02:20 PM
RESQ911's Avatar
Thanks Alex, I will shoot you an email.
Old Oct 18, 2006 | 02:52 PM
sharkster's Avatar
Sounds good as I said in the Email, I can't put that wing on this week (working like mad) and the tool hasn't been returned yet but I can scan the car anytime....
dhahlen
Nov 5, 2015 12:55 PM
