used 2002 GT2
Old Feb 9, 2004 | 05:29 AM
keoni1978's Avatar
keoni1978 is infamous around these parts
used 2002 GT2
what should I expect to pay for a used 2002 GT2 with approx 15,000 miles on it?
Old Feb 9, 2004 | 07:02 AM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
118 to 122 max
Old Feb 9, 2004 | 11:34 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
wow duane, that's almost lower than the low calls i make, that get owners' dander up. it's reality tho'.
what is not mentioned is the colour. assuming great condition:
silver, seal, slate 126
black, SY, 122
red, white" 115-110
Old Feb 9, 2004 | 11:40 AM
h20tt's Avatar
h20tt is infamous around these parts
Originally posted by watt
wow duane, that's almost lower than the low calls i make. what is not mentioned is the colour.
black, SY, 122
red, white" 115-110
Im surprised you didnt bunch black with the silver/greys, I thought it was "safe" for resale.
Old Feb 9, 2004 | 11:41 AM
keoni1978's Avatar
that sounds like a decent price. Is it possible to use it as a daily car?
Old Feb 9, 2004 | 12:14 PM
watt's Avatar
there is no better daily driver:
-elegant looks
-command presence
-rather quick, requires no mod.s unless you are an extraordinary driver
-stunning handling and braking
-starts, stops, totally bulletproof reliable
if you can only have 1 porsche it's the ONE
Old Feb 9, 2004 | 12:22 PM
keoni1978's Avatar
thanks for the info!!! Now its time for negotiation, hope I can hit that $118k
Old Feb 9, 2004 | 12:29 PM
DJ's Avatar
DJ
posted by watt :
"If you can only have 1 porsche it's the ONE"
NOT IF YOU LIVE IN NY
Old Feb 9, 2004 | 12:33 PM
keoni1978's Avatar
I dont know....roads in San Francisco are pretty bad too
Old Feb 9, 2004 | 12:43 PM
watt's Avatar
it's not bad roads [mine are quite bumpy], it's snow and ice that i would avoid or any chronic bad weather high speed driving -- if then, get a TT [996 or cayenne].
and it never snows in SFO!!!!!!!
Old Feb 9, 2004 | 01:55 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
best of luck getting it at 118. wholesalers in cali will offer more than that.
and despite what watt thinks, black is more desirable than SY.
black is worth as much as silver or seal. slate may be worth a tad bit more because it is a premium color ($3K option).
think about it, unless you are on the verge of bankruptcy, why would you give up a GT2 for 118-122?
i sense some market manipulation by some people here.
Old Feb 9, 2004 | 02:00 PM
DealMan's Avatar
DealMan is infamous around these parts
I would also recommend that you look at the PPCBs carefully and possibly have a dealer evaluate them, due to "bedding" issues that some people have experienced. The car should still be under warranty, but if the brakes were "abused" you might have an expensive repair bill.
Old Feb 9, 2004 | 02:11 PM
watt's Avatar
no pouting tyson!! he's talking 15K miles, and we still dont know what colour
Old Feb 9, 2004 | 02:15 PM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Why would a 2002 GT2 with 15k miles only be around 120k when a 2002 996 turbo with the same miles goes for around 90k. Does the GT2 depreciate faster for some reason? If anything I thought it would hold it's value better than a regular 996 turbo.
Old Feb 9, 2004 | 02:18 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
"Why would a 2002 GT2 with 15k miles only be around 120k when a 2002 996 turbo with the same miles goes for around 90k. "
not so different on a % basis of base MSRP.
"Does the GT2 depreciate faster for some reason?"
yep
