Wheel Question
Old Feb 9, 2004 | 07:01 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Wheel Question
I just ordered a set of Yoko Ono's AVS sports for my GT3...
I am thinking of buying another set of wheels for them and keep my PS2's on the OEM wheels. I like the forged Kinesis K-28's anodized. I think the grey anodize would look great on my car. Two questions:
1) what's the reverse lip option all about??? Is there an advantage or disadvantage as compared to standard lips???
2) Where to buy...I hear Wheel Experts now handles Kinesis...Can the wheels come in any offset??? ie, my requirements are:
Front: 8.5 J x 18 H2, 40mm offset
Rear: 11 J x 18 H2, 63mm offset
Thanks...
Old Feb 9, 2004 | 07:17 PM
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
The reverse lip option gives you the appearance of having a 19" wheel with only 18's. The more I see the less I know for sure.
Old Feb 9, 2004 | 07:26 PM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
I am going to be at Kinesis tomorrow Rockitman, if you have any question that you want me to ask them let me know.
Old Feb 9, 2004 | 07:27 PM
dbelleperc's Avatar
And yes they are all custom made.
Old Feb 9, 2004 | 07:29 PM
rockitman's Avatar
Are there any downsides to the reverse lip??? If they look bigger, but perform like 18's, that good..right???
Old Feb 9, 2004 | 07:34 PM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
The reverse lip goes straight back with no step in the lip as the standards. The 18R's use the same centers as a 19" standard since there is no step on the lips. There is no downside as I know. They are 18" wheels.... The Reverse lips are harder to mount rubber on, that is about it.
I had Kinesis K58R's and loved them.
MJC123's Avatar
Senior Member
Right!
p.s. the last sentence was a Lennon quote.
Old Feb 9, 2004 | 07:55 PM
rockitman's Avatar
Right!
Fitting for the Beatles 40th anniversary!!!
Reverse lips it is!!! Guess I need to give wheel experts a call. Can't imagine those wheels come cheap!!!
Then again, what does when it comes to Porsche's
Old Feb 9, 2004 | 08:09 PM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
The only downside to a reverse lip wheel is that it weighs about 1.5-2 lbs more than the same wheel with the standard rim halves, primarily due to the larger wheel center. However, given the weight of your standard GT3 wheels, you'll still do better (read...lighter) with any Kinesis forged wheel.
As for offset, they will be able to come very close to the factory specs -- probably ~ 38.5mm front and ~ 63.5mm for the rear. Of course, width will be exactly 8.5 and 11".
Old Feb 9, 2004 | 08:58 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
The only downside is that water can accumulate in the inside of the wheel and cause vibration at certain speeds. Im not sure if this is a characteristic of reverse lips, but I have talked to several HRE owners with the "R" model wheel who have experienced the same issues. Im not sure if this is a common occurence with these type of wheels in general (deep dish, etc.)? I had the same problem with my custom made forged wheels for my M3.
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
Sep 1, 2015 03:16 PM
Aug 21, 2015 09:56 AM
