Weird noise, from front passenger side.
Old Jan 4, 2007 | 07:10 AM
heavychevy's Avatar
It sounds like a pump of some sort but neil informed me that it might be the fan, It only happens when crusing at highway speeds in 4th 5th and 6th (or at least that's when I can hear it). It doesnt really sound like a fan though, it sounds like a pump of some sort, any one else ever hear this noise?
Old Jan 6, 2007 | 06:22 PM
45otto's Avatar
Kills Bugs Fast
45otto is infamous around these parts
Hissing air could be Wife of GFperhaps?
Old Jan 6, 2007 | 06:23 PM
MexicoBlue's Avatar
MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !
Beat me to the punch . . .
Old Jan 6, 2007 | 06:28 PM
heavychevy's Avatar
LOL, sounds more like a groan, still suitable though. Better than a whine, 5th gear usually does the trick.
Old Jan 6, 2007 | 06:40 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Turn the stereo up and it usally goes away.
Neil
Old Jan 6, 2007 | 07:23 PM
Turbo Fanatic's Avatar
That's the passenger screaming!
Old Jan 6, 2007 | 07:45 PM
5speed's Avatar
5speed is infamous around these parts
sent you a PM
Old Jan 7, 2007 | 12:27 AM
Westwood's Avatar
Westwood is infamous around these parts
I had a problem with my Boxster where there was a groaning sound and after much research it turned out to be a bad carbon control valve. Try putting a piece of tape over the air vent in the gas cap door and see if it goes away. It drove me nuts, but was easy to fix -- if this is it?
Roger
Old Jan 9, 2007 | 06:07 AM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
Could be a belt tensioner.
Old Jan 10, 2007 | 05:50 PM
heavychevy's Avatar
When I go pick up the car from Neil, I'm gonna drive around until it comes back so he can hear it. Then he can fix it.....problem solved.
Old Jan 10, 2007 | 06:02 PM
Is it a high pitched sound at low rpm in higher gears?
Old Jan 10, 2007 | 06:25 PM
Westwood's Avatar
Did you ever put a piece of tape over the air vent (not the drain) inside the gas cap. This will eliminate the carbon control valve that cause my groaning/honking sound. The line apparently draws air out of the gas door area to eliminate the gas fumes? My valve was cracked and at a certain rpm would make a really annoying noise. As in EMBARRESING noise.
It is worth a try to eliminate this. If you don't want to do it, have Neil try it.
Roger
Enemy
Nov 10, 2015 08:01 AM
rnl
Aug 26, 2015 02:36 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
manishdutta
Aug 21, 2015 09:49 AM
