help with wastegate adj.
Old Mar 29, 2007 | 10:21 PM
BUFFALOTT's Avatar
BUFFALOTT is infamous around these parts
i am currently adjusting the wastegates and i thought that i read that you want the gates to start to open around 11 p.s.i., i get around 7.5 p.s.i. and it seems the passenger side wastegate does not have as much travel to open and close at that p.s.i., is this normal when you start to adjust them to open at a higher p.s.i.. thanks
Old Mar 29, 2007 | 10:23 PM
do u have stock actuators? if so then they should crack open around 6 psi. if u have the aftermarkets then around 12 psi.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 29, 2007 | 10:36 PM
BUFFALOTT's Avatar
Yes They Are Stock Thanks
titannero
May 20, 2016 08:12 AM
panas001
Sep 27, 2015 02:51 PM
Jeanmarcboilard
Sep 22, 2015 05:03 PM
johnny.dangerous
Sep 14, 2015 02:19 AM
